Bar chart series item color not working
Macromullet
Post by Macromullet » Tue May 11, 2004 2:10 pm
I'm currently using build 1.1.1499.42325 of the product. I just had a bug report come in that series colors were wrong for one of my graphs. I have replicated the issue in the lab. Here is what i'm doing:
if (entry.status == STATUS_FAILED)
bar.Add(jentry.StartTime, newTime, Color.Red);
bar.Add(entry.StartTime, newTime, DEFAULT_BAR_COLOR);
I also have tried this:
bar.Add(entry.StartTime, newTime);
Neither one works. I get the series color for the majority of bars no matter what i do. It actually looks like it only colors the first point red, even though i have verified that the second point is red as well. I'm pretty confused at this point. Any help is greatly appreciated. If this is fixed in the latest build i can upgrade but I dont want to unless I have to because last time it was a struggle (gantt chart issues).
Macromullet
One thing i just found
Post by Macromullet » Tue May 11, 2004 2:15 pm
I was adding the bars right to left, that is, the first elements in the loop were actually the rightmost in the series (higher x value). I did a sort on the data prior to looping and now it looks like the colors are ok.
So, it may be a bug if you use colors per series item and the data is reverse ordered or just randomly ordered.
Post by Pep » Tue May 11, 2004 4:28 pm
I'm glad to hear this (that works now).
I've tried to reproduce the problem here so we can fix it for the next release but I cannot see the problem, could you please post a simple code or tell me the steps I must do to see it ?
