Graph values are clipped on the Y and X axis
Rhodies
Post by Rhodies » Mon Apr 05, 2004 11:52 pm
I find when I use the WebChart control that the last digits to the right on the X axis and to the top on the Y axis tend to get clipped from the viewing area of the graph.
Does anyone know how to prevent this ?
My initial guess is to increase the upper limits of both axis', but this is proving to be difficult.
Or
Can you specify a fixed increment ?
say for the x axis fix the increment amount to 5 which would read
0 5 10 15 20 25 30...
most of my graphs will fall in the same range and do not vary greatly.
Any help would be much appreciated.
thank you
Post by Pep » Tue Apr 06, 2004 4:03 pm
How about setting the ClipPoints property to False ? :
Chart.Aspect.ClipPoints = false;
Yes, you can set the desired increment, and Min/Max values for the axes like :
	WebChart1.Chart.Axes.Left.Increment = 5;
	WebChart1.Chart.Axes.Left.SetMinMax(0,50);
