I have vertical grid lines on Bottom Axis ..
How could i enlarge distance between dots in gridlines ?
Is it possible?
Hi glikoz,
You can set axes grid style like this:
If none of defined styles fits your needs you can also use DashPattern as shown here.
tChart1.Axes.Bottom.Grid.Style = System.Drawing.Drawing2D.DashStyle.Dash;
Hi glikoz,
Have you tried using DashPattern as in the example I posted at the thread I pointed you?
Please notice that this features was implemented in one of latest maintenance releases so this will only be supported Build 2.0.2546.16098/9 from 21st December 2006 or newer versions.
