Legend on the right gives an exception.
Release 1.1.2179.21092
When a teechart has a width > 1095 and the legend is positioned on the right. An excpetion is thrown each time you click on the legend tab.
To recreate...
Add a teechart onto a form.
Width set to 1096
Right click and edit.
Go to legend tab.
Arguement exception occurs: '1001' is not a valid value for 'Value'. 'Value' should be between 'Minimum' and 'Maximum'.
Vaughan
To recreate...
Width set to 1096
Go to legend tab.
Vaughan
Hi Vaughan,
I can not reproduce this here using the same release as you. Could you please give us some more information about your application environment or send us an example we can run "as-is" to reproduce the problem here?
Sorry,
I missed out a step before going to the legend tab.
All of this is done in designtime and also occurs at runtime.
Width set to 1096
Please add a tower series.
Go to legend tab.
Note, it gives similiar exceptions when you add different series types.
Width set to 1096
Go to legend tab.
Hi Vaughan,
Thanks for your reply but I'm still unable to reproduce it here. Have you checked on your project references that you use the build you mentioned?
Could you please let us know some more details about your environment (O.S., .NET Framework version, IDE Version, screen resolution, etc.).
Hi Vaughan,
Thanks for the information.
I've done several tests and haven't been able to reproduce this issue using Windows 2003 Server. However, the error could be reproduced in Windows XP but only at design-time. Could you please post the steps I should follow to reproduce it at run-time so that we can debug the project and try to find what's causing that error?
Thanks in advance for your feedback.
Add a Teechart onto a form.
Set the Width property to 1096.
Set the legend visible and to be displayed on the right.
Add a commander onto the form.
Set the Chart property of the commander to the Teechart just added.
Run
Maximise the running application to the full screen (1920x1200)
Press Edit on the commander.
Please add a tower series from the editor.
Go to legend tab in the editor.
The exception should occur.
Vaughan
Run
Vaughan
Hi Vaughan,
Thanks for the information. I couldn't use the same resolution as you, I used 1280x1024 and couldn't reproduce the problem here. Can you please test if this also happens in another machine?
Hi Vaughan,
After some testing I could reproduce the problem using a dual monitor configuration which gave me an overall resolution of 2560x1024. I reproduced the problem using the built you mentioned. However I couldn't reproduce it using our current TeeChart for .NET v1 sources. So, I've built new assemblies and I'll e-mail them, to your forums profile e-mail address, so that you can test if they work at your end. Could you please let us know which are the results?
Hi VH1,
I've tested this again and couldn't reproduce the issue here following the steps you originally mentioned. Is there anything else we can do to reproduce the issue here?
Hi VH1,
I can't reproduce the issue here using a 1280x1024 screen resolution and following the steps you mentioned.
Could you please check that TeeChart.dll reference in your projects is set to latest version available?
I have only one reference: 1.1.2531.28391
I see I missed out a step again...
Resolution set to 1600 by 1200.
Start with a form with width = 1100
Add a chart
Make the chart > 1096 width
Right click the chart
Select Edit
Add a bar series
Select Legend
You get the exception every time. Its that simple.
Add a chart
Select Edit
Add a bar series
Select Legend
