Setting color scales for the colorgrid
HQO
Post by HQO » Fri Jan 23, 2004 11:36 am
Question 1:
How I can specify the colors for each point in ColorGrid - series. For example, if value is lower than 3 then color of this point is yellow, if value is over 3 and lower than 4, the color of this point is green and so one...
Question 2:
Is there way to "disable" the automatic scalin in colorgrid series. Can I say that maximum value is 100 and minimun value is 0 and series use those information for color scaling. Now it's use maximum and minimum values from the data value array.
Thank's
Post by Pep » Tue Jan 27, 2004 10:35 am
you can do something like the following code :
		private void Form1_Load(object sender, System.EventArgs e)
			colorGrid1.FillSampleValues(50);
			//apply a new Palette
			colorGrid1.PaletteSteps=7;
			colorGrid1.ClearPalette();
			double dataRange=colorGrid1.YValues.Maximum-colorGrid1.YValues.Minimum;
			double minVal=colorGrid1.YValues.Minimum;
			colorGrid1.AddPalette(minVal+(dataRange*0.1),Color.DarkBlue);
			colorGrid1.AddPalette(minVal+(dataRange*0.2),Color.Blue);
			colorGrid1.AddPalette(minVal+(dataRange*0.3),Color.LightBlue);
			colorGrid1.AddPalette(minVal+(dataRange*0.5),Color.Yellow);
			colorGrid1.AddPalette(minVal+(dataRange*0.7),Color.YellowGreen);
			colorGrid1.AddPalette(minVal+(dataRange*0.8),Color.LightGreen);
			colorGrid1.AddPalette(minVal+(dataRange*0.9),Color.Green);
			colorGrid1.UseColorRange=false;
			colorGrid1.UsePalette=true;
			tChart1.Refresh();
