Hello TomAgos,
We have a demo of ours that you can check on our
github that explains this in more detail,
Line_Interpolate
to be precise.
Basically, through a function that looks like this
private double InterpolateLineSeries(Series series, int firstindex, int lastindex, double xvalue)
int index;
for (index = firstindex; index <= lastindex; index++)
if (index == -1 || series.XValues.Value[index] > xvalue) break;
// safeguard
if (index < 1) index = 1;
else if (index >= series.Count) index = series.Count - 1;
// y=(y2-y1)/(x2-x1)*(x-x1)+y1
double dx = series.XValues[index] - series.XValues[index - 1];
double dy = series.YValues[index] - series.YValues[index - 1];
if (dx != 0.0) return dy * (xvalue - series.XValues[index - 1]) / dx + series.YValues[index - 1];
else return 0.0;
and call it using the
colorLine.Value
as "xvalue", like so:
private void TChart1_AfterDraw(object sender, Steema.TeeChart.Drawing.IGraphics3D g)
// I'm using a try catch block to suggest an idea or approach, use as desired
try
double value = InterpolateLineSeries(fastLine, fastLine.FirstVisibleIndex, fastLine.LastVisibleIndex, colorLine.Value);
labelDisplay.Text = value.ToString();
catch(Exception e)
// Will only trigger if you remove the safety from InterpolateLineSeries() function
labelDisplay.Text = "ColorLine not in range of FastLine";
The way to implement this code is definitely up to you. For example, if you only have one colorLine and one series that you want to check if it intersects or where, you can adjust the header of the function, removing "Series" and "xvalue" as parameters etc.
Finally, this is an example of how it would look like, using a label on the right of the chart to show the value:
- ColorLineIntersection.png (27.71 KiB) Viewed 11765 times
Hope this helps, if there's anything else that I can help you with, please let me know!
Best regards,
Edu
