Application crashes after installing 6.2025.1.13, with the following error: Only one clip operation currently supported
Posted: Tue Feb 11, 2025 12:07 pm
by 30297515
I have up Steema Chart to 6.2025.1.13 and it crashes the app when displaying the main application window which contain five charts.
If i restored to 6.2024.11.6 and it works fine.
at Microsoft.Maui.Graphics.Win2D.W2DCanvasState.ClipPath(PathF path, WindingMode windingMode)
at Microsoft.Maui.Graphics.Win2D.W2DCanvas.ClipPath(PathF path, WindingMode windingMode)
at Steema.TeeChart.Maui.Drawing.CanvasMaui.ClipRectangle(Rect r)
at Steema.TeeChart.Maui.Drawing.Graphics3DBase.Steema.TeeChart.Drawing.IGraphics3D.ClipRectangle(Rectangle r)
at Steema.TeeChart.Tools.Annotation.DrawText(IGraphics3D g)
at Steema.TeeChart.Tools.Annotation.DrawText()
at Steema.TeeChart.Tools.Annotation.ChartEvent(EventArgs e)
at Steema.TeeChart.Tools.BannerTool.ChartEvent(EventArgs e)
at Steema.TeeChart.Chart.BroadcastToolEvent(EventArgs e)
at Steema.TeeChart.Chart.InternalDraw(Boolean noTools)
at Steema.TeeChart.Chart.InternalDraw()
at Steema.TeeChart.Maui.TChart.Draw(ICanvas g, RectF rect)
at Microsoft.Maui.Graphics.Win2D.W2DGraphicsView.OnDraw(CanvasControl sender, CanvasDrawEventArgs args)
at WinRT._EventSource_global__Windows_Foundation_TypedEventHandler_global__Microsoft_Graphics_Canvas_UI_Xaml_CanvasControl__global__Microsoft_Graphics_Canvas_UI_Xaml_CanvasDrawEventArgs_.EventState.<GetEventInvoke>b__1_0(CanvasControl sender, CanvasDrawEventArgs args)
at ABI.Windows.Foundation.TypedEventHandler`2.Do_Abi_Invoke[TSenderAbi,TResultAbi](Void* thisPtr, TSenderAbi sender, TResultAbi args)
Using Visual Studio : Microsoft Visual Studio Community 2022 (ARM 64-bit) - Preview
Version 17.13.0 Preview 5.0
DotNet : 9
MauiControl : 9.0.30
CommunityToolKit : 10.030
Re: Application crashes after installing 6.2025.1.13, with the following error: Only one clip operation currently suppo
Posted: Wed Feb 12, 2025 8:02 am
by Pep
can you pleae tell us in which platform this happens to you (windows, android or ios) ?
Posted: Wed Feb 26, 2025 11:23 am
by 30297515
Sorry, I took so long to response.
Windows !
Posted: Fri Feb 28, 2025 7:51 am
by Pep
Ok, no problem, let us do some checks here and back to you asap.
Posted: Tue Mar 11, 2025 11:46 pm
by Pep
could you please share me the code you're using ? or just tell me which series types you're drawing ?
I've been trying to reproduce the problem by usign some series types and all worked fine.
Maybe it's happenning at the time to draw something on canvas ?
Posted: Wed Mar 12, 2025 2:27 pm
by 30297515
After much research, the problem is caused by the use of your BannerTool.
I was dynamically creating a BannerTool in the ViewModel's InitializingChartControl() which is called in my constructor of the View.
If I comment out the creation and references to it, the application runs fine.
Sample creation code:
_BannerTool = new BannerTool(Chart);
_BannerTool.Shape.Color = System.Drawing.Color.Transparent;
_BannerTool.Shape.Font.Color = System.Drawing.Color.LightGray;
_BannerTool.Shape.Font.Size = 15;
_BannerTool.Shape.Shadow.Visible = false;
_BannerTool.Shape.Pen.Visible = false;
_BannerTool.Position = AnnotationPositions.Center;
_BannerTool.TextAlign = Steema.TeeChart.Drawing.StringAlignment.Center;
_BannerTool.Text = "";
Hope this help you!
Posted: Fri Mar 14, 2025 12:14 am
by Pep
it's strange, because I've just checked and it's working fine here by using a BannerTool.
Please, can you check if the attached sample demo that uses the code you sent to me, is working fine to you ?
MauiTest.zip
(223.65 KiB) Downloaded 37403 times
Posted: Sun Mar 16, 2025 10:08 pm
by 30297515
Your sample runs fine on my box.
Our application consists of 43 projects
It is a very large and complex application, so sending it to you is out of the question.
Hope to try to find some more time next week, to try narrow doing what else mine be contributing to the problem, but I am sure it connected to the usage of the BannerTool.
What source code BannerTool changes were made on your end between the previous and latest release of TChart. That is the only clue, I can give you at this time. Hopefully this helps.
Posted: Mon Mar 17, 2025 9:06 am
by Pep
thanks for your answer.
Sure, check in the case that you have time and let me know.
We've not done any special change in Banner Tool between latest version and the previous one, but I think that problem might be related to specific custom drawing on canvas.
In the case that you are drawing specific texts on canvas by using OnAfterDraw event or similar, just let me know, I think this could be related. This problem might happen when trying to draw addicional objects on canvas, and need to be fixed.
