Bottom subaxis manual text is not added
Posted: Thu Sep 05, 2024 9:22 am
by 16092152
Only the first sublaxis will be added and the rest will not work.
Is it possible to add subaxis label in Text rather than Datetime?
My environment is .net8 and wpf.
var line = new Steema.TeeChart.Styles.Line(Chart1.Chart);
Chart1.Axes.Bottom.Increment = 3;
var rnd = new Random();
for (var i = 0; i < 50; i++)
line.Add(i, rnd.Next(1000), i.ToString());
line.Pointer.Visible = true;
line.Pointer.VertSize = 2;
line.Pointer.HorizSize = 2;
var axis = Chart1.Axes.Bottom.SubAxes.Add();
axis.Visible = true;
axis.Grid.Visible = true;
axis.Increment = 1;
axis.Labels.Items.Add(i, i.ToString() +"_Sub");
axis.Grid.DrawEvery = 1;
axis.Labels.Angle = 90;
axis.Grid.Color = System.Drawing.Color.Red;
Re: Bottom subaxis manual text is not added
Posted: Thu Sep 05, 2024 3:33 pm
by edu
Adding these lines, your code should work.
axis.Maximum = 50;
axis.AutomaticMaximum = false;
You can learn more about other options for axes, such as custom axes and axis copy here: https://steema.com/docs/teechart/net/tu ... ntrol.htm
If there's anything else, let me know!
Best regards,
Edu
Posted: Fri Sep 06, 2024 1:59 am
by 16092152
I modified the code, but only the first one is the same, and the rest don't exist.
Posted: Fri Sep 06, 2024 6:26 am
by edu
I am reviewing this issue you're experiencing and want to make sure everything is up to date on your end. Could you verify if you're using our latest version? My tests are working fine on my end, so I just want to make sure we're on the same page.
Edu
