Some questions about AxisScroll
Posted: Wed Sep 06, 2023 9:13 am
by 15695007
If the series is this vertical, I want the current page to show only thirty series, and then the more series can be viewed by scrolling the X-axis (can you use the AxisScroll Tool? But this seems to work on the point.)
- Chart.png (32.1 KiB) Viewed 22871 times
Re: Some questions about AxisScroll
Posted: Fri Sep 15, 2023 1:24 am
by 15695007
Did you not see this problem? Can you reply as soon as possible?
Posted: Wed Sep 20, 2023 6:40 am
by Marc
Apologies for the delay replying.
It may be best to control it via your own forward and back buttons using Axis SetMinMax to set the minimum amn maximum dates to show and hence limit the visible points (or series) in this way.
