No width with multi-series one point bar charts.
Posted: Wed Feb 22, 2017 3:43 pm
by 15048900
I have a problem with bars in multiple series bar charts where each series has only one point in them.
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows.Forms;
namespace NoThicknessInSingleDataPointBarChart
        const int NUMBER_OF_POINTS = 1;
            tChart1.Aspect.View3D = true;
            for (int i = 0; i < 4; i++)
                Steema.TeeChart.Styles.Bar TheSeries = new Steema.TeeChart.Styles.Bar();
                TheSeries.MultiBar = Steema.TeeChart.Styles.MultiBars.None;
                TheSeries.Title = "Series-" + i.ToString();
                TheSeries.Marks.Visible = false;
                tChart1.Series.Add(TheSeries);
                for (int j = 0; j < NUMBER_OF_POINTS; j += 1)
                    TheSeries.Add(j + 1, "Label-" + j.ToString());
If NUMBER_OF_POINTS is set to 2 then you get:
If NUMBER_OF_POINTS is set to 1 then you get:
This is using the "Steema TeeChart for .NET 2016 4.1.2016.10260" of the library.
The "Steema TeeChart for .NET 2016 4.1.2016.05120" version of the library does not have this problem.
Re: No width with multi-series one point bar charts.
Posted: Wed Feb 22, 2017 4:04 pm
by Christopher
Unfortunately a similar issue has already been reported and fixed in id=1794. In the meantime, you should be able to set the CustomBarWidth to ameliorate the rendering in these particular cases:
        TheSeries.CustomBarWidth = 150;
