Legend and line issues with 3 Dimensions selected
Posted: Thu Jan 12, 2017 10:14 pm
by 15048900
I am having a couple of issues but I will explain what I am working with beforehand.
I start with a chart created with multiple Line series. The chart looks like:
- 3D-Off.PNG (15.64 KiB) Viewed 8911 times
if I turn on the 3D setting I get:
- 3D-On.PNG (16.89 KiB) Viewed 8910 times
The easiest way to duplicate this is to click the 3 Dimensions check box if tools is open:
- What I click.PNG (8.25 KiB) Viewed 8910 times
Now for the questions:
1) I want the boxes when 3D is turned off. The Legend lines in 2D mode are just too small for the user to sometimes tell the differences in the color. I have tried to change the Legend symbol and other things but nothing seems to work.
2) Why cannot I have the lines which are in 2D mode when 3D is turned on? The lines in 3D mode are really thick.
3) How do I get the "thick" lines in 2d mode?
Re: Legend and line issues with 3 Dimensions selected
Posted: Mon Jan 16, 2017 9:12 am
by Christopher
Hello!
This is what I get with this code:
tChart1.ShowEditor();
Line series = new Line(tChart1.Chart);
series.FillSampleValues();
firstly:
- threeD1.PNG (37.22 KiB) Viewed 8899 times
then having activated 3D:
- threeD2.PNG (49.72 KiB) Viewed 8896 times
do you get the same with this code? If so, could you please modify it so I can reproduce your issue here?
Posted: Tue Jan 17, 2017 3:02 pm
by 15048900
The only difference between your code and mine is you can add a line:
Please remember there are two issues. For the first issue:
Your code is fine. I see the same issue on your charts. You already are getting the Legend problem in your charts that I am getting. The "line" in 2D and the "block" when 3D is turned on.
For the second issue:
You are right I had a slight change in your code from mine:
series..Depth = series.LinePen.Width;
The default LinePen.Width is "1" and I noticed that if you make the value larger the change from 2D to 3D always doubles the value.
Posted: Fri Jan 20, 2017 9:38 am
by Christopher
Apologies for the delay in this reply.
My best suggestion is to use the technique shown in the demo under:
%programfiles(x86)% \Steema Software\Steema TeeChart for .NET 2016 4.1.2016.10260\Examples\DemoProject\bin\ExecutableDemo\TeeChartNetExamples.exe
All Features -> Welcome !\Miscellaneous\Legend\OnDrawSymbol Event
You could create small image file with a coloured rectangle.
You could try using the FastLine series instead of the Line series, which would give you:
tChart1.Aspect.View3D = true;
FastLine series = new FastLine(tChart1.Chart);
FastLine series1 = new FastLine(tChart1.Chart);
series1.FillSampleValues();
- TChart636205049547319377.png (16.41 KiB) Viewed 8865 times
The closest might be something like this:
Line series1 = new Line(tChart1.Chart);
series.LinePen.Width = 7;
series.LinePen.EndCap = System.Drawing.Drawing2D.LineCap.Round;
series1.LinePen.Width = 7;
series1.LinePen.EndCap = System.Drawing.Drawing2D.LineCap.Round;
- TChart636205054254545074.png (23.26 KiB) Viewed 8863 times
