XZ Grid with Y displacement
Posted: Tue Sep 08, 2015 9:55 pm
by 16075226
- OpenGL3D.png (315.88 KiB) Viewed 23455 times
I'm attempting to emulate the surface chart entitled "XZ Grid with Y displacement" from your gallery. I can't find it in your samples. I can reproduce the charting behaviour by activating Open GL, but then the axis labels are not shown properly (See above).
Can you help?
Re: XZ Grid with Y displacement
Posted: Wed Sep 09, 2015 4:53 am
by 16075226
This illustrates the absence of labels with openGL. Also,how do I remove the dashed gray lines from the (invisible) left wall?
Posted: Wed Sep 09, 2015 10:39 am
by Christopher
To make an image similar to this:
you can use the following code:
Surface series;
series = new Surface(tChart1.Chart);
series.FillSampleValues();
tChart1.Aspect.Zoom = 95;
tChart1.Aspect.Elevation = 295;
tChart1.Aspect.Perspective = 20;
tChart1.Aspect.Chart3DPercent = 35;
Posted: Wed Sep 09, 2015 6:37 pm
by 16075226
- EffectOfOpenGL.jpg (185.75 KiB) Viewed 23352 times
I'm afraid I'm still having problems.
In the image above, the same chart (without series data) has been rendered with and without OpenGL active.
I commented in or out the code below to achieve this effect:
Steema.TeeChart.Drawing.GL.TeeOpenGL openGL = new Steema.TeeChart.Drawing.GL.TeeOpenGL(SurfaceChart.Chart);
openGL.Active = true;
openGL.ShadeQuality = true;
Can you please explain:
1. How I can remove the dashed gray lines which are positioned on the left and bottom axes?
2. How I can make the axis labelling visible in the OpenGL rendering?
3. How I can increase the font size of the axis labels (It seems to be stuck on 'Verdana 8') whatever I set in the property editor?
Many thanks,
Andy
Posted: Thu Sep 10, 2015 8:27 am
by Christopher
Using this code:
Surface series;
Steema.TeeChart.Drawing.GL.TeeOpenGL openGL;
openGL = new Steema.TeeChart.Drawing.GL.TeeOpenGL(tChart1.Chart);
//series.FillSampleValues();
tChart1.Header.Text = "openGL.Active " + openGL.Active;
tChart1.Draw();
openGL.Active = !openGL.Active;
tChart1.Aspect.Zoom = openGL.Active ? 60 : 95;
I obtain the following images:
- export635774703354528973.png (24.71 KiB) Viewed 23350 times
- export635774703395922503.png (9.95 KiB) Viewed 23348 times
Can you please modify the above code so I can reproduce your issue here?
Posted: Thu Sep 10, 2015 8:55 pm
by 16075226
Dear Christopher,
I've solved questions 1 and 2:
1. The gray lines are the Grid lines of the Depth Axis and are removed by setting Axes.Depth.Grid.Visible to false.
2. In my version of Teechart (Steema TeeChart for .NET Source Code 2015 4.1.2015.08060) changing the font in properties (eg Axes.Bottom.Labels.Font) does not work. By default, it is set to Verdana, 8pt and it reverts to this font whatever one chooses. However, changing it by code (eg Axes.Bottom.Labels.Font.Size = 14) works quite happily.
I still not able to work out how to position axis labels correctly when open GL is active. I suspect that the labels are being printed, but in a different orientation.
I note that in your own example, when OpenGL is active, the left and bottom axis zeroes are not shown either.
Andy
Posted: Mon Sep 14, 2015 8:35 am
by Christopher
Hello Andy,
Anaesthesia wrote:I still not able to work out how to position axis labels correctly when open GL is active. I suspect that the labels are being printed, but in a different orientation.
Unfortunately this is a defect which I have added to our tracking system with
id=1302. Every effort will be made to find a fix to this defect before the next maintenance release. Apologies for any inconvenience in the meantime.
Posted: Mon Sep 14, 2015 6:52 pm
by 16075226
Thank you. - I'm still extremely pleased with the graphs I generate!
Andy
Posted: Tue Sep 15, 2015 2:50 pm
by Christopher
Anaesthesia wrote:Thank you. - I'm still extremely pleased with the graphs I generate!
That's excellent, I'm very pleased to hear it.
I've now fixed the issue with the axis labels in OpenGL. It is a very simple fix, and if you have the source code version you may be interested in me passing it to you.
Posted: Wed Sep 16, 2015 8:17 am
by 16075226
Dear Christopher,
I have the source code version. Could you let me know what to do?
Andy
Posted: Wed Sep 16, 2015 9:21 am
by Christopher
Andy,
Anaesthesia wrote:I have the source code version. Could you let me know what to do?
Of course. There are two changes, both of them to the unit CanvasGL.cs under:
%Program Files%\Steema Software\Steema TeeChart for .NET Source Code 2015 4.1.2015.08060\Sources\TeeChart.OpenGL
and they are shown in the following two images:
- diff1.PNG (58.13 KiB) Viewed 23265 times
- diff2.PNG (58.75 KiB) Viewed 23255 times
Posted: Wed Sep 16, 2015 7:30 pm
by 16075226
When I replace the method (as shown below) and attempt to re-compile, I get:
Error 1 'Steema.TeeChart.Drawing.GL.GraphicsGL.TextOut(int, int, string, bool)': no suitable method found to override
Code Snippet:
//public override void TextOut(int x, int y, string text)
// TextOut(x,y,0,text);
public override void TextOut(int x, int y, string text, bool allowHtml)
TextOut(x, y, 0, text, false);
Posted: Wed Sep 16, 2015 7:36 pm
by Christopher
Anaesthesia wrote:When I replace the method (as shown below) and attempt to re-compile, I get:
In the second image I think one can see that the signature to override is slightly different, i.e.
Steema.TeeChart.Drawing.GL.GraphicsGL.TextOut(int, int, int, string, bool)
not
