Vertical Line Alignment
Posted: Fri Mar 27, 2015 12:05 pm
by 16071129
We are facing performance issue while aligning vertical line (i.e. Color Line Tool, AXIS=Bottom) in two charts as shown in attached image.
Vertical Line not Aligned while mouse is moving
Vertical Line 1.JPG (24.75 KiB) Viewed 7838 times
Vertical Line aligned while mouse is stopped at any location
Vertical Line 2.JPG (25.29 KiB) Viewed 7846 times
While moving mouse, vertical line in second chart lags behind vertical line of first chart.
Please help us to resolve this issue.
Re: Vertical Line Alignment
Posted: Fri Mar 27, 2015 12:25 pm
by narcis
Hi Quant,
Is this the same problem you posted here? Otherwise, could you please attach a Short, Self Contained, Correct (Compilable), Example?
Posted: Mon Mar 30, 2015 6:06 am
by 16071129
Please find attached sample code of vertical line alignment.
Vertical Line.zip
(20.09 KiB) Downloaded 752 times
Posted: Mon Mar 30, 2015 9:55 am
by Christopher
Quant wrote:Please find attached sample code of vertical line alignment.
Vertical Line.zip
I think this issue is identical to the one you posted here, and so the solution to it is the one I posted in that thread.
