Left Title cut off in Teechart IOS
cbrandin
Post by cbrandin » Wed Jan 28, 2015 2:37 am
I just converted my apps to 64 bit IOS and ran into a small problem. The left axis title (set to 90 degrees) gets cut off. I appears to always do it. It looks like the autosizing isn't calculating correctly. There is a simple work around fortunately. If you append a bunch of spaces (20, or so) to the end of the title it seems to work correctly, and it also appears to ignore the extra spaces when positioning the title.
Chris
Re: Left Title cut off in Teechart IOS
Post by Pep » Mon Feb 02, 2015 3:08 pm
Hello Chris,
thanks for the advise. I can reproduce the problem here. I'm trying to fix it for the next maintenance release. I'll back to you with some news asap.
