Keeping Aspect Ration: Going wrong
Posted: Thu Apr 10, 2014 10:11 am
by 15668832
I have problem in keeping aspect ratio whenever the size of client changes.
The attached solution works partly and I do not know what mistake I made there...
Any help will be greatly appreciated.
Re: Keeping Aspect Ration: Going wrong
Posted: Thu Apr 10, 2014 2:19 pm
by 15668832
Any help will be appreciated...
Posted: Thu Apr 10, 2014 3:11 pm
by Christopher
Hello Raavi,
As an alternative, you can use one of the Series.IsoHorizAxes or Series.IsoVertAxes, e.g.
- isoaxis.PNG (16.47 KiB) Viewed 11658 times
if you use both at the same time you will get the effect that your code gets - this effect is unavoidable, I'm afraid, the isoaxes can only be for horizontal or vertical directions, not both.
Posted: Thu Apr 10, 2014 3:27 pm
by 15668832
Re: Keeping Aspect Ratio: Going wrong
Posted: Fri Apr 11, 2014 9:30 am
by 15668832
I have one more problem, that aspect ratio is not kept when I press maximize button.
Posted: Fri Apr 11, 2014 12:53 pm
by 15668832
May I know whether it is possible to set IsoHorizAxes or IsoVertAxes to a Chart than a Series?
Right now, I add series with 'IsoHorizAxes = true' to a Chart and set Chart.Dock to Dockfill.
This way does not set the IsoHorizAxes until I change the size of the Chart or Pan the Chart.
Posted: Mon Apr 14, 2014 8:23 am
by Christopher
Raavi wrote:I have one more problem, that aspect ratio is not kept when I press maximize button.
I've been able to reproduce this here and have added it to our bug database with
id=721. I've spent some time trying to find a workaround to this problem, but unfortunately without success.
Posted: Mon Apr 14, 2014 8:25 am
by Christopher
Raavi wrote:May I know whether it is possible to set IsoHorizAxes or IsoVertAxes to a Chart than a Series?
No, at the moment these properties only belong to the Series class, enabling some series to render "Iso" while others render normally.
Raavi wrote:Right now, I add series with 'IsoHorizAxes = true' to a Chart and set Chart.Dock to Dockfill.
This problem is doubtless related to the
id=721 bug I mentioned in my last post. Again, I'm afraid I haven't been able to find a workaround to this issue.
Posted: Mon Apr 14, 2014 8:40 am
by 15668832
Good Morning,
Thank you very much indeed.
