axis labels and title overlaping for many vertical axes
Posted: Thu Mar 27, 2014 2:23 pm
by 15666633
Hi, i use multiple custom vertical axis, and place it on some distance from each other on the left side. when values are quiet large threre is oveplapping of title of axis and its labels, to solve it i turned FixedLabelSize property to false, as someone rocended on this forum, but after that have to move all other axes to the proper place. Bellow you can see a part of a code.
public double Min
get
m_Min = m_Axis.Minimum;
return m_Min;
set
m_Min = value;
m_Axis.AutomaticMinimum = false;
int WidthBefore = m_Axis.Labels.Width;
m_Axis.FixedLabelSize = false;
m_Axis.Minimum = value;
Helper.RecaclulateAxisIncrement(CAxesHolder.GetAxesIncrement(), m_Axis);
FitAxes(WidthBefore);
private void FitAxes(int WidthBefore)
m_TChart.Refresh();
int delta = m_Axis.Labels.Width - WidthBefore;
ResetPosition(delta);
m_TChart.Refresh();
m_Axis.FixedLabelSize = true;
public double Max
get
m_Max = m_Axis.Maximum;
return m_Max;
set
m_Max = value;
m_Axis.AutomaticMaximum = false;
int WidthBefore = m_Axis.Labels.Size.Width;
m_Axis.Maximum = value;
private void ResetPosition(double delta)
m_TChart.Panel.MarginLeft += delta;
int index = m_TChart.Axes.Custom.IndexOf(m_Axis);
for (int i = index + 1; i < m_TChart.Axes.Custom.Count; ++i)
m_TChart.Axes.Custom[i].RelativePosition -= delta;
you can see that i do absolutely same things for setting minimum and maximum, but in case of minimum everything works fine, but with minimum it doesn't. So what am i doing wrong, and probably you can offer me another way to solve this problem?
Re: axis labels and title overlaping for many vertical axes
Posted: Fri Mar 28, 2014 10:12 am
by Christopher
Petr wrote:you can see that i do absolutely same things for setting minimum and maximum, but in case of minimum everything works fine, but with minimum it doesn't. So what am i doing wrong, and probably you can offer me another way to solve this problem?
Would you be so kind as to give me a fuller code example of your problem? I can't run the example you gave and even if I could I don't think I'd be able to fully understand what the issue is. The kind of example I'm looking for is explained
here.
Many thanks.
Posted: Fri Mar 28, 2014 12:25 pm
by 15666633
Hi Christopher!
https://www.dropbox.com/s/lr2fbfz0ht31k0y/trunk.rar here you can find my project with test application. Here's the build order:
1. idl
2. DataController
3. PainterComponent
4. GrapherComponent
5. TRNGraph
6. InteropApp( c++ project, this is the test application )
try to run application, add some plots, and press parameter properties button on the parameter in the list(thre's a tooltip). try to change min and max fields
you are interested in PainterComponent, which is TeeChart Wrapper. In this porject there are classes CAxisHolder and CAxis. in CAxisHolder metod AddAxis Creates CAxis( wrapper of Steema.TeeChart.Axis). and Max/Min accesors are in CAxis.
p.s This links is also can be used to understand the problem in my post
http://www.teechart.net/support/viewtop ... =4&t=14809.
Posted: Fri Mar 28, 2014 1:37 pm
by Christopher
Petr wrote:here you can find my project with test application. Here's the build order:
I think I must be doing something wrong. I start with this:
- debug1.PNG (19.06 KiB) Viewed 25543 times
but when I build I get this:
- debug2.PNG (12.89 KiB) Viewed 25541 times
Posted: Mon Mar 31, 2014 8:12 am
by 15666633
Hi Chrostopher! Probably you have a different path to regtlibv12.exe, in this case you can try to change the path in Command line in Post-Build events property page of idl project. On the othe hand i can say you that you don't need to complie idl and InteropApp, because they are already compiled to bin folder, so you can find them there. So, i hope, with managed projects you won't have any problems.
Posted: Mon Mar 31, 2014 10:36 am
by Christopher
Hi Petr,
I would like to use the source code for TeeChart and TeeChart.Direct2D - will I not need to recompile everything to be able to use it?
Is there no way you can send me a simple Windows Forms example of the problem you have? Using the project you sent is going to take a little time for me to learn how to use it.
Posted: Mon Mar 31, 2014 12:28 pm
by 15666633
Unfortunately it won't be much easier. More than this i attached it not only for this topic, but for two more also, so i think that it even will be easier for you to understand this and other problems.
no, you do not need to recompile unmanaged parts, maximaly you need to register ..\bin\TrnGraphInterop.tlb with regtlibv12.exe.
Posted: Mon Mar 31, 2014 2:10 pm
by Christopher
Christopher wrote:Unfortunately it won't be much easier. More than this i attached it not only for this topic, but for two more also, so i think that it even will be easier for you to understand this and other problems.
Okay. To avoid me spending too much time on trying to get this project to run on my machine, would you be so kind as to give me very simple, step-by-step instructions which I can follow to get it to run?
Posted: Mon Mar 31, 2014 2:50 pm
by 15666633
Ofcourse, firstly you should build order is, DataController, PainterComponent, GrapherComponent, TRNGraph. after that you should start InteropApp from bin and attach to it. TeeChart is used in PainterComponent. thanks for response.
Posted: Mon Mar 31, 2014 3:17 pm
by Christopher
Petr wrote:Ofcourse, firstly you should build order is, DataController, PainterComponent, GrapherComponent, TRNGraph. after that you should start InteropApp from bin and attach to it. TeeChart is used in PainterComponent. thanks for response.
I'm very sorry, but I'm afraid I don't understand those instructions. My questions are:
1) how do I set the buildorder?
2) how to I attach to the Interop? (and what do I attach to it?)
Posted: Tue Apr 01, 2014 5:21 am
by 15666633
The build order is:
1. DataController
2. PainterComponent
3. GrapherComponent
4. TRNGraph
To attach to InteropApp you shoul start it from bin folder and chose Tools->Attach to Process from Visual Studio main menu, chose InteropApp from the list and click Attach button.
I have to apologize for this difficultis, and i decided to make a simple project on C# that will change InteropApp, but it will take some time, so, if you would be so kind, and succesfull in attachiing to existing application, i'll be glad to get an answer.
Posted: Tue Apr 01, 2014 8:55 am
by Christopher
Petr wrote:To attach to InteropApp you shoul start it from bin folder and chose Tools->Attach to Process from Visual Studio main menu, chose InteropApp from the list and click Attach button.
I'm sorry too, Petr, for not being able to get your project to run!
I've just started with your trunk.rar again, extracting it to a new folder. I've opened it with VS2013 (upgrading the projects) and then in release mode have built the projects in the order you specified. I then try running InteropApp.exe in the trunk\InteropApp\Release folder and windows gives me a "InteropApp.exe has stopped working message". Any ideas please?
Posted: Fri Apr 11, 2014 8:08 am
by 15666633
Hi, finaly i made a simple project, that shows problems only for this topic. here you should change values of min and max fields and see the icorrect behaviour of vertical axes.
Posted: Mon Apr 14, 2014 9:37 am
by Christopher
Petr wrote:Hi, finaly i made a simple project, that shows problems only for this topic. here you should change values of min and max fields and see the icorrect behaviour of vertical axes.
Thank you Petr. How about trying something similar to this:
private const int m_AxesWidth = 50;
Steema.TeeChart.Axis m_Axis1;
Steema.TeeChart.Axis m_Axis2;
Steema.TeeChart.Axis m_Axis3;
InitAxis(ref m_Axis1, "axis1");
InitSeries(m_Axis1);
InitAxis(ref m_Axis2, "axis2");
InitSeries(m_Axis2);
InitAxis(ref m_Axis3, "axis3");
InitSeries(m_Axis3);
tChart1.AfterDraw += tChart1_AfterDraw;
g.Pen.Width = 2;
g.Pen.Color = Color.Red;
g.HorizontalLine(m_Axis2.Title.Right - g.FontHeight , m_Axis2.Position, m_Axis2.Title.Bottom);
private void InitSeries(Axis axis)
Steema.TeeChart.Styles.FastLine fl = new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
fl.FillSampleValues(20);
fl.CustomVertAxis = axis;
tChart1.Axes.Custom.Add(axis);
private void InitAxis(ref Axis axis, string title)
axis = new Steema.TeeChart.Axis();
axis.Title.Caption = title;
axis.Title.AutoPosition = true;
axis.Title.Angle = 90;
axis.Automatic = false;
axis.SetMinMax(0, 10);
axis.PositionUnits = Steema.TeeChart.PositionUnits.Pixels;
axis.RelativePosition = -m_AxesWidth * tChart1.Axes.Custom.Count;
axis.Labels.OnAxis = true;
private void max_ValueChanged(object sender, EventArgs e)
m_Axis2.AutomaticMaximum = false;
m_Axis2.Maximum = (double)max.Value;
int width = m_Axis2.Position - (m_Axis2.Title.Right - tChart1.Graphics3D.FontHeight);
if (m_AxesWidth - width < 10 && m_Axis3.RelativePosition != ((-m_AxesWidth * 2) - (m_AxesWidth - width)))
m_Axis3.RelativePosition -= m_AxesWidth - width;
else if (!(m_AxesWidth - width < 10) && m_Axis3.RelativePosition != (-m_AxesWidth * 2))
m_Axis3.RelativePosition = (-m_AxesWidth * 2);
