How to ues Direct2D in WPF application?
Posted: Wed Feb 26, 2014 9:10 am
Examples\DemoProjectDirect2D, The only run in winform
Steema Software - Customer Support Forums
http://teechart.com/support/
Yes, that's true. TeeChart.Direct2D.dll is compiled with TeeChart.dll and not TeeChart.WPF.dll.zrandlbs wrote:How to ues Direct2D in WPF application?
I used to .Net Framework 4.0(VS2010) to work.Christopher wrote:Yes, that's true. TeeChart.Direct2D.dll is compiled with TeeChart.dll and not TeeChart.WPF.dll.zrandlbs wrote:How to ues Direct2D in WPF application?
At the moment I'm changing the source to create TeeChart.WPF.Direct2D.dll to see if it works reliably. Would you like to test such a dll? If so, which .NET framework version do you work in?
Okay. It will be a few working days before we can make the TeeChart.WPF.Direct2D.dll public, but I will let you know as soon as it becomes available.zrandlbs wrote:I used to .Net Framework 4.0(VS2010) to work.
No problem, Candy, I will let you know too when this assembly is ready.Candy wrote:Hello Christopher,I would like to participate in the test, you can also send a copy to my TeeChart.WPF.Direct2D.dll do?
I used to .Net Framework 4.0(VS2010,Windows7) to work.
Just to let you know that a beta-version of TeeChart.WPFDirect2D.dll is available from here.Christopher wrote:Okay. It will be a few working days before we can make the TeeChart.WPF.Direct2D.dll public, but I will let you know as soon as it becomes available.zrandlbs wrote:I used to .Net Framework 4.0(VS2010) to work.
Again, just to let you know that a beta-version of TeeChart.WPFDirect2D.dll is available from here.Christopher wrote:No problem, Candy, I will let you know too when this assembly is ready.Candy wrote:Hello Christopher,I would like to participate in the test, you can also send a copy to my TeeChart.WPF.Direct2D.dll do?
