Xamarind.Android System.Drawing.Color != Android.Color
Posted: Wed Jan 15, 2014 10:58 am
by 17365504
Hi.
For xamarin android teecharts we use System.Drawing.Colors. For native controls we use Android.Graphics.Color.
But with the same argb components they look different. For example #333333 color in System.Drawing.Color on charts is darker than Android.Graphics.Color?
Maybe there is some property in TChart like shadow which can change chart look, but i can't find it. Alpha is set to opaque.
How to make equal colors?
Re: Xamarind.Android System.Drawing.Color != Android.Color
Posted: Wed Jan 15, 2014 12:47 pm
by narcis
Hi Thomas,
Where does this occur in TeeChart? By default, some TeeChart pens are automatically slightly darkened for aesthetic purposes.
BTW, you may also be interested in the Steema.TeeChart.Utils.ToAndroidColor(Color r); method that transforms a System.Drawing.Color color to Android.Graphics.Color.
    /// <summary>
    ///Converts a System.Drawing.Color to Android.Graphics.Color
    /// </summary>
    public static Android.Graphics.Color ToAndroidColor(Color r)
      return new Android.Graphics.Color(r.ToArgb());
Posted: Fri Jan 17, 2014 11:42 am
by narcis
Hi Thomas,
NarcĂ­s wrote:By default, some TeeChart pens are automatically slightly darkened for aesthetic purposes.
You can still eliminate this effect as I suggested here though.
Posted: Thu Jan 30, 2014 11:52 am
by 17365504
Hi!
It appears in CircularGauge.FaceBrush.Color.
Pen color doesn't help to solve this issue.
Steema.TeeChart.Utils.ToAndroidColor() returns correct color, but it looks darker on the screen.
Posted: Thu Jan 30, 2014 12:49 pm
by narcis
Hi Thomas,
Thanks for your reply. Ok, the problem is not about pens but brushes. I created a chart using this code:
    private Steema.TeeChart.TChart tChart1;
      tChart1 = new Steema.TeeChart.TChart(this);
      Steema.TeeChart.Themes.BlackIsBackTheme myTheme = new Steema.TeeChart.Themes.BlackIsBackTheme(tChart1.Chart);
      myTheme.Apply();
      string hexColor = "#333333";
      ColorConverter converter = new ColorConverter();
      Color c = (Color)converter.ConvertFromString(hexColor);
      Steema.TeeChart.Styles.CircularGauge circularGauge1 = new Steema.TeeChart.Styles.CircularGauge(tChart1.Chart);
      circularGauge1.FaceBrush.Gradient.Visible = false;
      circularGauge1.FaceBrush.Color = c;
      tChart1.Panel.Gradient.Visible = false;
      tChart1.Panel.Color = c;
      SetContentView(tChart1);
Which produced this chart:
I copied a section of the CircularGauge over the panel to compare colors:
Honestly, using latest TeeChart for Xamarin.Android build (v4.13.12.13) from December 2013, I can not see any difference between circularGauge1.FaceBrush.Color and tChart1.Panel.Color. This can also be seen in red, for example:
Can you see any color differences? Can you reproduce the problem with the code I posted? If not, can you please modify my code snippet so that we can reproduce the problem here? Finally, which TeeChart for Xamarin.Android build are you using?
Posted: Thu Jan 30, 2014 1:11 pm
by 17365504
The difference appearance not between FaceBrush and Panel colors.
It appears between android LinearLayout background color and Chart Panel color.
Sorry for misleading information.
Posted: Thu Jan 30, 2014 2:37 pm
by narcis
Hi Thomas,
I can not reproduce the problem using the code below either:
      myTheme.Apply();
      //c = Color.Red;
      tChart1.Zoom.Style = Steema.TeeChart.ZoomStyles.Classic;
      LinearLayout layout = new LinearLayout(this);
      layout.SetBackgroundColor(Steema.TeeChart.Utils.ToAndroidColor(c));
      layout.AddView(tChart1, new ViewGroup.LayoutParams(ViewGroup.LayoutParams.FillParent, 400));
      SetContentView(layout);
It produces those screenshots:
Does this code work fine at your end? Can you please modify it so that we can reproduce the problem here?
