csv file data on teechart wpf 4.1.2012.1312 version
gilbert
Post by gilbert » Mon May 27, 2013 11:19 am
I am using teechart wpf 4.1.2012.1312 version.
I need to bind the csv file data into teechart where csv file can contain time(on teechart x axis) and pressure(on teechart y axis) values.
I have problem in binding csv file data.
Please help me to show csv file data on teechart.
Re: csv file data on teechart wpf 4.1.2012.1312 version
Post by Sandra » Mon May 27, 2013 3:12 pm
Hello gilbert,
You can use TextSource and do something as do in next lines of code to import the .csv file I have attached:
        public MainWindow()
        private Steema.TeeChart.WPF.Styles.Line Series1;
            //Auxiliar series.
            Series1 = new Steema.TeeChart.WPF.Styles.Line(tChart1.Chart);
            //Read Text File
            Steema.TeeChart.WPF.Data.TextSource ts = new Steema.TeeChart.WPF.Data.TextSource(@"C:\Test.csv");
            ts.HeaderLines = 1;
            ts.DecimalSeparator = '.';
            ts.Separator = ' ';
            ts.Fields.Add(0, "Y");
            //Assign Text File to Series1;
            Series1.DataSource = ts;
            Series1.XValues.DataMember = "X";
            Series1.YValues.DataMember = "Y";
Test.zip
(167 Bytes) Downloaded 624 times
gilbert
Post by gilbert » Tue May 28, 2013 11:56 am
Thank you Sandra.
how can we show multiple series on teechart at a time from different csv files.
Also please let me know how can I customize the values on x axis and y axis.
Post by Sandra » Wed May 29, 2013 12:04 pm
Hello gilbert,
If you want use multiple series and import its values from different .csv files I recommend you use multiple TextSource to import the .csv files, you can do something as next:
 private Steema.TeeChart.WPF.Styles.Line Series1,Series2;
            //Auxiliar series.
            Series2 = new Steema.TeeChart.WPF.Styles.Line(tChart1.Chart);
            //Read Text Files
            Steema.TeeChart.WPF.Data.TextSource ts1 = new Steema.TeeChart.WPF.Data.TextSource(@"C:\Test1.csv");
            ts.HeaderLines = 1;
            ts.Separator = ' ';
            ts1.HeaderLines = 1;
            ts1.DecimalSeparator = '.';
            ts1.Separator = ' ';
            ts1.Fields.Add(0, "Y");
            //Assign Text File to Series2;
            Series2.DataSource = ts1;
            Series2.XValues.DataMember = "X";
            Series2.YValues.DataMember = "Y";
I have attached other file data .csv, because you can make the test with my code.
Test1.zip
(168 Bytes) Downloaded 606 times
If you want use custom values to axis x and y you can use SetMinMax() method, for each axis. On the other hand, I recommend taking a look in the TeeChartFor.Net Demo project, concretely in All Features\Welcome !\Axes. The examples, were made in Winforms but all funcionalities should work fine in the wpf projects
gilbert
Post by gilbert » Thu May 30, 2013 12:00 pm
Thank you Sandra.
