TeeChart for Xamarin.iOS v2012 4.13.04.05 available
Gemma
Post by Gemma » Tue Apr 09, 2013 7:58 am
Steema is pleased to inform you that TeeChart for Xamarin.iOS v2012 build 4.13.04.05 is now available.
TeeChart for Xamarin.iOS customers with valid license subscription may download the version at no-charge from the customer download page .
Release notes for the build may be viewed at the version info page .
For a fully functional evaluation version please follow this link to the NET evaluations download page.
Gemma Gibert
Karl
Re: TeeChart for Xamarin.iOS v2012 4.13.04.05 available
Post by Karl » Fri Apr 19, 2013 10:40 pm
Hi, I'm trying to use TeeChart but there is a problem:
When compiling, if I don't change linker options to "Don't link" (and then app become bigger) it gets a compilation error.
Then, with "Don't link" when I run it on device (on Simulator it's ok), I get:
System.ExecutionEngineException: Attempting to JIT compile method 'Steema.TeeChart.Styles.SeriesCollection:.ctor (Steema.TeeChart.Chart)' while running with --aot-only. See http://docs.xamarin.com/ios/about/limitations for more information.
at Steema.TeeChart.Chart.initVars () [0x00000] in <filename unknown>:0
at Steema.TeeChart.Chart..ctor () [0x00000] in <filename unknown>:0
at Steema.TeeChart.TChart..ctor () [0x00000] in <filename unknown>:0
at MyApp.FormProdutividadeRX.CarregaGrafico () [0x00021] in /Users/karl/Projects/MyApp/MyApp.iPad/FormProdutividadeRX.xib.cs:92
at MyApp.FormProdutividadeRX.webBrowserRelatorio_ShouldStartLoad (MonoTouch.UIKit.UIWebView webView, MonoTouch.Foundation.NSUrlRequest request, UIWebViewNavigationType navigationType) [0x0018f] in /Users/karl/Projects/MyApp/MyApp.iPad/FormProdutividadeRX.xib.cs:74
at MonoTouch.UIKit.UIWebView+_UIWebViewDelegate.ShouldStartLoad (MonoTouch.UIKit.UIWebView webView, MonoTouch.Foundation.NSUrlRequest request, UIWebViewNavigationType navigationType) [0x0000d] in /Developer/MonoTouch/Source/monotouch/src/UIKit/UIWebView.g.cs:589
at MonoTouch.UIKit.UIApplication.Main (System.String[] args, System.String principalClassName, System.String delegateClassName) [0x0004c] in /Developer/MonoTouch/Source/monotouch/src/UIKit/UIApplication.cs:38
at MyApp.Application.Main (System.String[] args) [0x00033] in /Users/karl/Projects/MyApp/MyApp.iPad/Main.cs:37
How can this be corrected? I'm using latest Xamarin Studio, Xamarin.iOS, Mono framework and MacOS 10.8.3.
Karl
Post by Narcís » Wed Apr 24, 2013 9:29 am
Hi Karl,
Please see Sandra's reply here.
