some questions about TeeChart
when we use the Teechart there is some questions can you help me? please see the Attachment thanks!
- TeeChart.zip
- (65.79 KiB) Downloaded 549 times
Re: some questions about TeeChart
Hello Candy,
If you want get the values of a determinate selection values. I recommend you taking a look in this link where are discussing about this topic. If you have any problems, please let me know.Can I Marquee the chart and get the Sequence data (please see the picturec)?
I want to get this data and draw a new chart how can I do
Yes, I recommend you taking a look in the All features\Welcome !\Chart styles\Financial\Point and Figure to know as you do to create this type of Financial Charts.2:dose Teechart support this Type of Chart? Thanks!
is there any sample about web chart about this? thanks!
Hello Candy,
I have made for you a simple code using the rectangle of ZoomTool to get the data sequence value using web chart.
Could you tell us if previous code help you?
On the other hand, if you want know as you do to create Point and Figure Financial Chart using TeeChartFor.Net Asp Chart I recommend taking a look in Chart Styles\ Financial\Point and Figure example of Demo Asp.
private Steema.TeeChart.Tools.ZoomTool tool1;
private System.IO.MemoryStream tmpChart;
protected void Page_Load(object sender, System.EventArgs e)
Steema.TeeChart.Chart ch1 = WebChart1.Chart;
tmpChart = new System.IO.MemoryStream();
if (Session["ch1"] == null)
ch1.AutoRepaint = false;
ch1.Aspect.View3D = false;
//Tool Zoom
ch1.Tools.Add(new Steema.TeeChart.Tools.ZoomTool(WebChart1.Chart));
tool1.ZoomPenColor = System.Drawing.Color.OliveDrab;
ch1.Panel.Gradient.Visible = false;
ch1.Walls.Visible = false;
ch1.Series.Add(new Steema.TeeChart.Styles.Points());
ch1[0].FillSampleValues();
ch1[1].FillSampleValues();
ch1.Export.Template.Save(tmpChart);
//save template to a Session variable
Session.Add("ch1", tmpChart);
//retrieve the session stored Chart
tmpChart = (System.IO.MemoryStream)Session["ch1"];
//set the Stream position to 0 as the last read/write
//will have moved the position to the end of the stream
tmpChart.Position = 0;
//import saved Chart
WebChart1.Chart.Import.Template.Load(tmpChart);
System.Drawing.Bitmap bmp = WebChart1.Chart.Bitmap((int)WebChart1.Width.Value, (int)WebChart1.Height.Value);
myMethod();
//If you want use zoom you only need uncoment CheckZoom
// CheckZoom(WebChart1);
//Use My method to get the rectangle zoom coordinates.
private void myMethod()
Hashtable ht = getZoomArgs(Request);
int X0 = Convert.ToInt32(ht["x0"]);
int Y0 = Convert.ToInt32(ht["y0"]);
int X1 = Convert.ToInt32(ht["x1"]);
int Y1 = Convert.ToInt32(ht["y1"]);
ListBox1.Items.Clear();
if ((X0 != -1) && (Y0 != -1))
foreach (Steema.TeeChart.Styles.Series s in WebChart1.Chart.Series)
for (int i = 0; i < s.Count; i++)
if (CheckSeriesPoints(s, i, X0, Y0, X1, Y1))
ListBox1.Items.Add("Series:"+s.Title+"Point " + i.ToString() + ": " + s.XValues[i].ToString() +
", " + s.YValues[i].ToString());
//CheckSeriesPoint is in the rectangle or not.
private bool CheckSeriesPoints(Steema.TeeChart.Styles.Series s, int index, int X0,int Y0, int X1, int Y1)
return ((s.CalcXPos(index) >= X0) && (s.CalcXPos(index) <= X1) && (s.CalcYPos(index) >= Y0) && (s.CalcYPos(index) <= Y1));
//Do zoom.
private void CheckZoom(Steema.TeeChart.Web.WebChart wChart)
System.Collections.ArrayList zoomedState = (System.Collections.ArrayList)Session[Request.QueryString["filename"] + "Zoomed"];
System.Drawing.Bitmap bmp = WebChart1.Chart.Bitmap((int)wChart.Width.Value, (int)wChart.Height.Value);
if (wChart.Chart.Tools.Count > 0)
zoomedState = ((Steema.TeeChart.Tools.ZoomTool)wChart.Chart.Tools[0]).SetCurrentZoom(Request, zoomedState);
if (zoomedState != null)
Session.Add(Request.QueryString["filename"] + "Zoomed", zoomedState);
Session.Remove(Request.QueryString["filename"] + "Zoomed");
//Need to get arguments of Zoom tool to allow you calculate rectangle.
protected Hashtable getZoomArgs(HttpRequest r)
Hashtable argumentList = new Hashtable();
if ((r.Params["__EVENTARGUMENT"] != null) && (r.Params["__EVENTARGUMENT"].Length > 0))
char[] pairs = new char[1] { ';' };
char[] vals = new char[1] { '$' };
String[] varpairs = r.Params["__EVENTARGUMENT"].Split(pairs);
foreach (string s in varpairs)
if (s.IndexOf("$") != -1)
argumentList.Add(s.Split(vals)[0], s.Split(vals)[1]);
return argumentList;
