Blurry Back Wall Image
Posted: Tue May 15, 2012 8:38 am
by 15662208
Hello!
We're trying to migrate to TeeChart.NET (2012 4.1.2012.05100) from older Active X version (v2010). Active X version used to produce sharp (aliased) background image:
- ActiveX.png (5.94 KiB) Viewed 12040 times
Analogious code re-writen to TeeChart.NET produces blurry (anti-aliased) background image:
- NET.png (14.69 KiB) Viewed 12027 times
To maintain backward compatibility we need to produce sharp (aliased) background image using TeeChart.NET (this is very important for our needs). Do you have any idea how to achieve that?
I you want, I can provide my source code... but it's very easy to reproduce - just create a small bitmap image using e.g. Paint and load it to back wall of a chart.
Re: Blurry Back Wall Image
Posted: Tue May 15, 2012 3:06 pm
by 10050769
Hello Anatoly,
I can not reproduce your problem using next code and last version of TeeChartFor.Net:
Series1 = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
Series1.FillSampleValues();
tChart1.Draw();
tChart1.Walls.Back.Brush.Image = Image.FromFile(@"Test.bmp");
tChart1.Walls.Back.Brush.Gradient.Visible = false;
And also I have attached the image I have used to make the test
- Test.zip
- (2.95 KiB) Downloaded 395 times
Can you try if your problem appears using my code and my image?
Posted: Wed May 16, 2012 3:09 am
by 15662208
Sandra,
Thank you much for responding! And I'm sorry for not being clear in the first place, I should have provided my code. I use
export to BMP:
Chart chart = new Chart();
Bar bar;
bar = new Bar(chart);
bar.FillSampleValues();
chart.Aspect.View3D = false;
chart.Walls.Back.Gradient.Visible = false;
chart.Walls.Back.Brush.Image = Image.FromFile(@"d:\TEMP\Untitled.bmp");
BitmapFormat bitmap = chart.Export.Image.Bitmap;
bitmap.Width = 400;
bitmap.Height = 300;
bitmap.Save(@"d:\TEMP\output.bmp");
Also attaching my "Untitled.bmp" and "output.bmp" images. As you can see in output.bmp, the back wall image is anti-aliased.
It is reproducible with your BMP as well, but your BMP is quite large itself and smoothing is not that obvious. While my BMP is small and this where I get undesired smoothing.
Posted: Wed May 16, 2012 3:53 am
by 15662208
Here is another example just to make the issue really obvious. In this attachement:
background.bmp - very small (1x3 pixels) bitmap to appear on the back wall of a chart
Ax.bmp - desired output generated with TeeChart Active X v2010
NET.bmp - incorrect output generated with TeeChart.NET
Thanks!
Posted: Wed May 16, 2012 9:45 am
by 10050769
Hello Anatoly,
I have inform you that we have imported image directly in the Form and image we have loaded in background appears blurry (anti-aliased) and is the same result you get if you blow up the image with image Editor, therefore it is behavior produced for the way that .Net Framework has to treat the images bitmap when their ImageMode is streach. To check it I have made a simple code without TChart:
BackgroundImage = Image.FromFile(@"C:\Users\Sandra\Downloads\TeeChartIssue\background.bmp");
BackgroundImageLayout = ImageLayout.Stretch;
And I have gotten next results:
- TestBmp.jpg (50.27 KiB) Viewed 11991 times
Would be very helpful gpt us. if you can send me the code you have used in Activex, because, we can try to find a solution for you using TeeChartFor.Net
Thanks in advance,
Posted: Wed May 16, 2012 3:52 pm
by 15662208
Sure, here is my Active X code that produce correct output. This code is in C# and it invokes TeeChart via interop.
ITChart chart = new TChartClass();
ISeries series = chart.Series(chart.AddSeries(ESeriesClass.scBar));
series.FillSampleValues();
Bitmap b = new Bitmap(@"d:\TEMP\background.bmp");
chart.Walls.Back.Picture.AssignImage(b.GetHbitmap().ToInt32());
IBMPExport bitmap = chart.Export.asBMP;
bitmap.Width = 400;
bitmap.SaveToFile(@"d:\TEMP\Ax.bmp");
And another note that may help...
export to Metafile produces correct (aliased) output even with TeeChart.NET.
Posted: Thu May 17, 2012 1:59 pm
by 10050769
Hello Anatoly,
Would be very helpful if you can tell us with which version of ActiveX you made the code because using last version of ActiveX and your code I cannot get the same results as you and I get next result:
- TestAx.jpg (65.89 KiB) Viewed 11992 times
Thank,
Posted: Thu May 17, 2012 2:50 pm
by 15662208
Well, I used v2010 and v2011 - it works all the same. I think you're not getting the same result as I did because you're not doing the same thing. On your screen capture you have a control while what I'm talking about here is export to BMP. Could you please try my exact code?
Posted: Fri May 18, 2012 2:30 pm
by narcis
Hi Anatoly,
This is a .NET framework feature. Check out this code:
using System;
using System.ComponentModel;
using System.Data;
using System.Drawing;
using System.Linq;
using System.Text;
using System.Windows.Forms;
namespace WindowsFormsApplication1
public class myControl : Panel
private Image image;
public Image Image
get { return image; }
set { image = value; }
protected override void OnPaint(PaintEventArgs e)
base.OnPaint(e);
Rectangle dest = new Rectangle(0, 0, this.Width, this.Height);
Rectangle src = new Rectangle(0, 0, image.Width, image.Height);
//e.Graphics.InterpolationMode = System.Drawing.Drawing2D.InterpolationMode.NearestNeighbor;
//e.Graphics.PixelOffsetMode = System.Drawing.Drawing2D.PixelOffsetMode.None;
e.Graphics.DrawImage(image, dest, src, GraphicsUnit.Pixel);
Image image = Image.FromFile(@"c:\TEMP\Untitled.bmp");
tChart1.Walls.Back.Gradient.Visible = false;
tChart1.Walls.Back.Brush.Image = image;
tChart1.Draw();
myControl p = new myControl();
p.Width = rect.Width;
p.Height = rect.Height;
p.Left = rect.Left;
p.Top = tChart1.Bottom;
p.Image = image;
this.Controls.Add(p);
It plots a custom Panel with a background image the very same way TeeChart does. Now try uncommenting the lines that set
Graphics.InterpolationMode and
Graphics.PixelOffsetMode at
myControl's
OnPaint override. Those are the properties that make a difference here. I added this issue (TF02016191) to the wish-list to be investigated for future releases. Probably it would make most sense setting those properties as shown in the example when changing
TChart.Aspect.SmoothingMode, for example:
tChart1.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.None;
In the meantime, if you are a source code customer, you can modify it at
Steema.TeeChart.Drawing.Graphics3DGDIplus.Draw(Rectangle destRect, Rectangle srcRect, Image image, bool transparent) in CanvasGDIplus.cs.
Posted: Sat May 19, 2012 7:56 am
by 15662208
Hi Narcís,
Thanks a lot! I will try to leverage this information to get the desired result. Unfortunatelly I'm not a source code customer... so do you have any any idea when this issue could be addrressed on your side?
Anatoly
Posted: Mon May 21, 2012 4:10 am
by 15662208
I was trying to use your idea in conjunction with Chart.Draw(Graphics g, Rectangle r) method and it almost worked. The image is now sharp but it is not aligned correctly:
- 1.jpg (39.72 KiB) Viewed 11994 times
The background is drawn in the top-left part of the chart. Compare to the output of Active X version:
- Ax.jpg (46.42 KiB) Viewed 11995 times
Posted: Mon May 21, 2012 4:32 am
by 15662208
Here is the corresponding code:
Bar bar;
chart.Walls.Back.Brush.Image = Image.FromFile(@"d:\TEMP\background.bmp");
Bitmap b = new Bitmap(400, 300);
Graphics g = Graphics.FromImage(b);
g.InterpolationMode = System.Drawing.Drawing2D.InterpolationMode.NearestNeighbor;
g.PixelOffsetMode = System.Drawing.Drawing2D.PixelOffsetMode.None;
chart.Draw(g, new Rectangle(0, 0, 400, 300));
g.Dispose();
b.Save(@"d:\temp\1.bmp");
Posted: Mon May 21, 2012 2:43 pm
by narcis
Hi Anatoly,
In that case I think it's much easier custom drawing on the chart canvas as shown here:
tChart1.Chart.Aspect.View3D = false;
tChart1.Series.Add(new Steema.TeeChart.Styles.Bar(tChart1.Chart)).FillSampleValues();
tChart1.BeforeDrawSeries += new Steema.TeeChart.PaintChartEventHandler(tChart1_BeforeDrawSeries);
tChart1.Export.Image.JPEG.Save(@"c:\temp\customdrawing.jpeg");
void tChart1_BeforeDrawSeries(object sender, Steema.TeeChart.Drawing.Graphics3D g)
Rectangle chartRect = tChart1.Chart.ChartRect;
Rectangle rect = new Rectangle(chartRect.Left, 100, chartRect.Width, 100);
g.Pen.Visible = false;
g.Brush.Color = Color.Red;
g.Rectangle(rect);
Which produces this image for me:
- customdrawing.jpeg (37.89 KiB) Viewed 11932 times
Does this fit your needs or do you needs?
Posted: Tue May 22, 2012 4:53 am
by 15662208
Hi Narcís,
Thanks! Using a combination of your workarounds I was able to solve the problem.
Anatoly
