ChartListBox - Get Index (SeriessIndex) of active Series
AGF
Post by AGF » Sat Apr 02, 2011 8:28 am
I am Working with three Panels witch are including a galleryPanel, TChart and ChartListBox.
How can i get the Index of the selected Series in an ChartListBox to use it to Change the Series.Style with the galleryPanle in VB.Net.
Thanks and Best Regards
Re: ChartListBox - Get Index (SeriessIndex) of active Series
Post by Yeray » Mon Apr 04, 2011 10:46 am
Hi AGF,
I'm not sure to understand how would you exactly want it to respond. It would be helpful if you could arrange a simple example project we can run as-is to reproduce the situation here.
Post by Sandra » Mon Apr 04, 2011 11:01 am
Hello AGF,
I'm not sure if this is what you are trying to do but this lines of code seems that achieve to series of index you are indicated:
 Dim series As Steema.TeeChart.Styles.Series
        series = ChartListBox1.Items.Item(0)
if it's not what you were trying to do, please arrange the example Yeray was asking for.
AGF
Post by AGF » Mon Apr 04, 2011 11:17 am
What i am looking for is to get the Item() Index number of the currently at the ChartlistBox selected .Items.item()
Post by Sandra » Tue Apr 05, 2011 9:16 am
Hello AGF,
I suggested that use property of ChartListBox SelectedIndex and SelectedIndexChanged Event as do in next example of code:
        Steema.TeeChart.Styles.Line Series1, Series2;
            Series1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            Series2 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            Series1.FillSampleValues();
            Series2.FillSampleValues();
            chartListBox1.Items.Add(Series1);
            chartListBox1.Items.Add(Series2);
            chartListBox1.SelectedIndexChanged += new EventHandler(chartListBox1_SelectedIndexChanged);
        void chartListBox1_SelectedIndexChanged(object sender, EventArgs e)
            int j = chartListBox1.SelectedIndex;
Could you tell us, if previous code help you to solve your problem?
AGF
Post by AGF » Wed Apr 06, 2011 6:17 am
Dear Sandra,
yes it helps me to fix my problem
