Adjusting start position of axis
Posted: Sun Nov 14, 2010 9:42 am
by 15057312
I need to adjust the aspect ratio of the points chart. If I set the Left and right axis start position to 25%
Points1.Chart.Axes.Left.StartPosition = 25
Points1.Chart.Axes.Right.StartEndPositionUnits = Steema.TeeChart.PositionUnits.Percent
Points1.Chart.Axes.Right.StartPosition = 25
The Left and Right Axis plot correctly, but if I add the top axis, it does not plot in the correct position
Points1.Chart.Axes.Right.Visible = True
Points1.Chart.Axes.Bottom.Visible = True
Points1.Chart.Axes.Left.Visible = True
Points1.Chart.Axes.Top.Visible = True
See picture
- Points1.jpg (49.1 KiB) Viewed 7665 times
Re: Adjusting start position of axis
Posted: Mon Nov 15, 2010 11:03 am
by 10050769
Hello lilo,
I suggest you, use property of Axes RelativePosition for change position of Top axis, as do in next example:
for (int i = 0; i < 5; i++)
Steema.TeeChart.Styles.Points series1 = new Steema.TeeChart.Styles.Points(tChart1.Chart);
series1.FillSampleValues(10);
series1.Pointer.HorizSize = 7;
series1.Pointer.VertSize = 7;
if (i < 2)
series1.VertAxis = Steema.TeeChart.Styles.VerticalAxis.Right;
series1.HorizAxis = Steema.TeeChart.Styles.HorizontalAxis.Top;
tChart1.Axes.Left.StartPosition = 25;
tChart1.Axes.Right.StartEndPositionUnits = Steema.TeeChart.PositionUnits.Percent;
tChart1.Axes.Right.StartPosition = 25;
tChart1.Axes.Top.RelativePosition = 25;
Could you tell us, if previous code works fine for you?
Posted: Mon Nov 15, 2010 8:22 pm
by 15057312
This works OK, but a new problem is introduced. The labels on the top axis are not positioned correctly. See picture.
- Points2.jpg (63.19 KiB) Viewed 7664 times
Posted: Tue Nov 16, 2010 12:11 pm
by 10050769
Hello lilo,
I couldn't reproduce your problem using last version of TeeChart.Net. I have got next image where axes labels see correctly:
- Chart1.jpg (51.93 KiB) Viewed 7629 times
Please, you could send us a simple project so we can reproduce your problem here? Also, can you say us what number of build of version 4 are you using now?
