Gantt chart problems
Brinet
Post by Brinet » Thu Nov 04, 2010 9:10 am
I have a following problem(s). On a gantt chart I want to show duration of all selected projects in the
database. On the bottom axis years are shown and on the left axis project names.
Begin of each gantt chart bar is in the year when project was started and end in the year of
project finalization. However on my gantt chart the first label on bottom axis is always missing.
And I don't now how to set a bottom axis so that all relevant starting and ending years are shown.
In addition on my chart the bars are always to close to the left axis as in the attached image.
Also when I have only two bars, as in the example I have sent to you, bars are to far from each other.
My code is the following and the result I get is in the attachment. As you can see it doesn't look very
representativ and we can't show such chart to our customer.
         private Steema.TeeChart.TChart chart;
        private Steema.TeeChart.Styles.Gantt ganttSeries1;
        private Steema.TeeChart.Tools.GridBand gridBand1;
        String[] heatNumber;
        public Gantt_Chart2()
            InitializeChart1();
        private void InitializeChart1()
            chart = FindName("tChart") as Steema.TeeChart.TChart;
            this.chart.Series.Clear();
            String[] names = { "BHUSHAN CON", "BHUSHAN LF" };
            DateTime[] start = new DateTime[2];
            DateTime[] end = new DateTime[2];
            start[0] = new DateTime(2005, 4, 14, 0, 0, 0);
            end[0] = new DateTime(2009, 4, 14, 0, 0, 0);
            start[1] = new DateTime(2005, 4, 14, 0, 0, 0);
            end[1] = new DateTime(2009, 4, 14, 0, 0, 0);
            heatNumber = new String[2];
            heatNumber[0] = "45 387";
            heatNumber[1] = "568";
            if (ganttSeries1 == null)
                ganttSeries1 = new Steema.TeeChart.Styles.Gantt();
            ganttSeries1.Clear();
            this.tChart.Series.Add(ganttSeries1);
            for (int i = 0; i < start.Length; i++)
                //System.Windows.Forms.MessageBox.Show(start[i].ToString() + " " + end[i].ToString());
                ganttSeries1.Add(start[i], end[i], i, names[i].ToString());
            this.gridBand1 = new Steema.TeeChart.Tools.GridBand();
            for (int i = 0; i < ganttSeries1.Count; i++)
                tChart.Axes.Left.Labels.Items.Add(ganttSeries1.YValues[i], ganttSeries1.Labels[i]);
            // tChart1
            // tChart1.Aspect
            this.tChart.Aspect.SmoothingMode = System.Drawing.Drawing2D.SmoothingMode.HighQuality;
            this.tChart.Aspect.TextRenderingHint = System.Drawing.Text.TextRenderingHint.ClearTypeGridFit;
            this.tChart.Aspect.View3D = false;
            this.tChart.Axes.Bottom.Labels.Style = AxisLabelStyle.Value;
            // tChart1.Header
            tChart.Header.Visible = true;
            this.tChart.Header.Font.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(64)))), ((int)(((byte)(64)))), ((int)(((byte)(64)))));
            this.tChart.Header.Font.Size = 11;
            this.tChart.Header.Font.SizeFloat = 11F;
            this.tChart.Header.Font.Bold = true;
            this.tChart.Header.Text = "Available number of heats";
            // tChart1.Panel
            // tChart1.Panel.Brush
            this.tChart.Panel.Brush.Color = System.Drawing.Color.FromArgb(((System.Byte)(254)), ((System.Byte)(255)), ((System.Byte)(255)), ((System.Byte)(255)));
            this.tChart.Panel.Bevel.Inner = BevelStyles.None;
            this.tChart.Panel.Bevel.Outer = BevelStyles.None;
            this.tChart.Tools.Add(gridBand1);
            tChart.Walls.Visible = false;
            // tChart1.Walls
            // tChart1.Walls.Back
            // tChart1.Walls.Back.Brush
            this.tChart.Walls.Back.Brush.Color = System.Drawing.Color.FromArgb(((System.Byte)(254)), ((System.Byte)(255)), ((System.Byte)(255)), ((System.Byte)(255)));
            this.tChart.Walls.Back.Transparent = false;
            // tChart1.Walls.Bottom
            // tChart1.Walls.Bottom.Pen
            this.tChart.Walls.Bottom.Pen.Visible = false;
            this.tChart.Walls.Bottom.Size = 3;
            // tChart1.Walls.Left
            // tChart1.Walls.Left.Pen
            this.tChart.Walls.Left.Pen.Visible = false;
            this.tChart.Walls.Left.Size = 3;
            // ganttSeries1
            ganttSeries1.ColorEach = true;
            // ganttSeries1.EndValues
            ganttSeries1.EndValues.DataMember = "End";
            ganttSeries1.EndValues.DateTime = true;
            ganttSeries1.LabelMember = "Labels";
            // ganttSeries1.LinePen
            ganttSeries1.LinePen.Color = System.Drawing.Color.FromArgb(((System.Byte)(254)), ((System.Byte)(64)), ((System.Byte)(64)), ((System.Byte)(64)));
            // ganttSeries1.Marks
            // ganttSeries1.Marks.Symbol
            // ganttSeries1.Marks.Symbol.Shadow
            ganttSeries1.Marks.Symbol.Shadow.Height = 1;
            ganttSeries1.Marks.Symbol.Shadow.Visible = true;
            ganttSeries1.Marks.Symbol.Shadow.Width = 1;
            // ganttSeries1.NextTasks
            ganttSeries1.NextTasks.DataMember = "NextTask";
            // ganttSeries1.Pointer
            // ganttSeries1.Pointer.Brush
            //ganttSeries1.Pointer.Brush.Color = System.Drawing.Color.Red;
            ganttSeries1.Pointer.Brush.ForegroundColor = System.Drawing.Color.Empty;
            ganttSeries1.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
            // ganttSeries1.StartValues
            ganttSeries1.StartValues.DataMember = "Start";
            ganttSeries1.StartValues.DateTime = true;
            ganttSeries1.Title = "gantt1";
            // ganttSeries1.YValues
            ganttSeries1.YValues.DataMember = "Y";
            ganttSeries1.ShowInLegend = false;
            ganttSeries1.ConnectingPen.Visible = false;
            // gridBand1
            this.gridBand1.Axis = this.tChart.Axes.Left;
            // gridBand1.Band1
            this.gridBand1.Band1.Color = System.Drawing.Color.FromArgb(((System.Byte)(76)), ((System.Byte)(192)), ((System.Byte)(192)), ((System.Byte)(192)));
            // gridBand1.Band2
            this.gridBand1.Band2.Color = System.Drawing.Color.FromArgb(((System.Byte)(76)), ((System.Byte)(255)), ((System.Byte)(255)), ((System.Byte)(255)));
            tChart.Axes.Left.MinimumOffset = 10;
            tChart.Axes.Left.MaximumOffset = 10;
            tChart.Axes.Left.AxisPen.Visible = false;
            tChart.Axes.Left.Grid.Visible = false;
            tChart.Axes.Bottom.Grid.Visible = false;
            this.tChart.Axes.Left.Ticks.Visible = false;
            tChart.Axes.Bottom.MinorTicks.Visible = false;
            tChart.Axes.Left.MinorTicks.Visible = false;
            tChart.Axes.Left.Labels.Transparent = true;
            ganttSeries1.Marks.Transparent = true;
            ganttSeries1.Marks.Visible = true;
            ganttSeries1.Marks.ArrowLength = -25;
            ganttSeries1.Pointer.VertSize = 10;
            ganttSeries1.Pointer.Pen.Visible = false;
                ganttSeries1.GetSeriesMark += new Series.GetSeriesMarkEventHandler(ganttSeries1_GetSeriesMark);
            DateTime sss = DateTime.FromOADate(ganttSeries1.StartValues.Minimum);
            sss.AddYears(-2);
            DateTime eee = DateTime.FromOADate(ganttSeries1.EndValues.Maximum);
            eee = eee.AddYears(1);
            // Set horizontal bottom axis minimum and maximum
            this.tChart.Axes.Bottom.SetMinMax(sss, eee);
            this.tChart.Axes.Bottom.Increment = Steema.TeeChart.Utils.GetDateTimeStep(Steema.TeeChart.DateTimeSteps.OneYear);
            this.tChart.Axes.Bottom.Labels.DateTimeFormat = "yyyy";
            foreach (AxisLabelItem item in this.tChart.Axes.Left.Labels.Items)
                item.Font.Bold = true;
                item.Font.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(64)))), ((int)(((byte)(64)))), ((int)(((byte)(64)))));
                item.Font.Size = 11;
                item.Font.SizeFloat = 11F;
            Annotation annot1 = new Annotation(tChart.Chart);
            annot1.Text = DateTime.FromOADate(ganttSeries1.StartValues.Minimum).ToString("yyyy");
            annot1.Active = true;
            annot1.Position = AnnotationPositions.LeftBottom;
            annot1.Left = 110;
            annot1.Top = 370;
        void ganttSeries1_GetSeriesMark(Series series, GetSeriesMarkEventArgs e)
                       e.MarkText = heatNumber[e.ValueIndex];
Thank you in advance.
image.zip
(7.02 KiB) Downloaded 560 times
Re: Gantt chart problems
Post by Narcís » Thu Nov 04, 2010 12:17 pm
Hi Brinet,
First of all I simplified your code a little bit so that unnecessary code didn't distract me :P.
I found much easier removing custom labels and doing this:
      this.tChart1.Axes.Bottom.Increment = Steema.TeeChart.Utils.GetDateTimeStep(Steema.TeeChart.DateTimeSteps.OneYear);
      this.tChart1.Axes.Bottom.Labels.DateTimeFormat = "yyyy";
      int minYear = DateTime.FromOADate(ganttSeries1.StartValues.Minimum).Year;
      int maxYear = DateTime.FromOADate(ganttSeries1.EndValues.Maximum).Year;
      DateTime startDate = DateTime.Parse("01/01/" + minYear.ToString());
      DateTime endDate = DateTime.Parse("01/01/" + (maxYear + 1).ToString());
      tChart1.Axes.Bottom.SetMinMax(startDate, endDate);
Complete example is:
      this.tChart1.Aspect.View3D = false;
      tChart1.Walls.Visible = false;
      this.tChart1.Header.Text = "Available number of heats";
      //this.tChart1.Axes.Bottom.Labels.Style = Steema.TeeChart.AxisLabelStyle.Value;
      tChart1.Axes.Left.MinimumOffset = 10;
      tChart1.Axes.Left.MaximumOffset = 10;
      tChart1.Axes.Left.AxisPen.Visible = false;
      tChart1.Axes.Left.Grid.Visible = false;
      this.tChart1.Axes.Left.Ticks.Visible = false;
      tChart1.Axes.Bottom.MinorTicks.Visible = false;
      tChart1.Axes.Left.MinorTicks.Visible = false;
      tChart1.Axes.Bottom.Grid.Visible = false;
      Steema.TeeChart.Styles.Gantt ganttSeries1 = new Steema.TeeChart.Styles.Gantt(tChart1.Chart);
Getting "2005" label visible already solves that, doesn't it?
You have several options here:
1. Make gantt bars wider:
      ganttSeries1.Pointer.VertSize = 30;
2. Set left axis minimum and maximum values:
      tChart1.Axes.Left.SetMinMax(ganttSeries1.MinYValue() - 2, ganttSeries1.MaxYValue() + 2);
3. Increase left axis minimum and maximum offset:
      tChart1.Axes.Left.MinimumOffset = 50;
      tChart1.Axes.Left.MaximumOffset = 50;
Hope this helps!
Brinet
Post by Brinet » Thu Nov 04, 2010 1:17 pm
Thank a lot!!!! :D It works perfectly now.
