Show Axes Even with NO data
Posted: Fri Oct 22, 2010 1:46 pm
How do I show the axes, instead of an ugly blank chart, even before the series have been added to the chart?
Steema Software - Customer Support Forums
http://teechart.com/support/
Steema.TeeChart.Styles.Line series1;
tChart1.Aspect.View3D = true;
series1 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
tChart1.Axes.Left.SetMinMax(0, 500);
tChart1.Axes.Bottom.SetMinMax(0, 100);
series1.FillSampleValues();
I fear that it is not possible, you need add series,because chart can calculate value its axes.Is there any way to do this without adding an empty series?
You don't need treat series are you using for calculate axes of chart as series phantom. I recommend you, use first series you add in chart for initialize axes, as a valid series, you only have added its values.I handle events and currently assume that all series that exist on my chart are valid. I'd have to develop code specifically to handle these (phantom series) that have to be added when the chart is first initialized.
