Bug in ColorGrid Legend using Palette
TEh
Post by TEh » Mon Aug 30, 2010 6:52 am
The legend shows wrong colors when using own palette
The example below runs ok with version 3.2 showing in legend colors red, yellow, white, turquoise and blue.
With the latest 4.1 version the colors shown are wrong (some colors shown twice)
To use the example just create a form test.vb in windows.forms vb project referencing the appropriate teechart version
and replace the contents of created test.vb with code below.
Imports Steema.TeeChart
Public Class test
    Private zValues(23) As Double
    Private ScaleColors() As Color
    Private ScalePoints() As Double
    Private iRangeCount As Integer = 5
    Private dRMin As Double
    Private dRMax As Double
    Private dTarget As Double
    Private dColorStep As Double
    Private TChart1 As New Steema.TeeChart.TChart
    Private ColorGrid1 As New Steema.TeeChart.Styles.ColorGrid
    Private Sub test_Load(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles MyBase.Load
        TChart1.Aspect.View3D = False
        ColorGrid1.IrregularGrid = False
        ColorGrid1.ShowInLegend = True
        ColorGrid1.UsePalette = True
        ColorGrid1.UseColorRange = False
        TChart1.Legend.Series = ColorGrid1
        TChart1.Legend.MaxNumRows = 5
        TChart1.Legend.LegendStyle = LegendStyles.Palette
        TChart1.Series.Add(ColorGrid1)
        Me.Controls.Add(TChart1)
        SetData()
    Private Sub SetData()
        Dim iC As Integer
        Dim iAdd As Integer = 0
        Dim rG As New System.Random
        ColorGrid1.ClearPalette()
        ColorGrid1.Clear()
        ' create random data
        iC = 0
        dRMin = Double.MaxValue
        dRMax = Double.MinValue
        For x As Integer = 0 To 3
            For y As Integer = 0 To 5
                zValues(iC) = rG.NextDouble
                If zValues(iC) < dRMin Then dRMin = zValues(iC)
                If zValues(iC) > dRMax Then dRMax = zValues(iC)
                iC += 1
            Next
        Next
        SetScalePointsAndScaleColors()
        ' Add palettes
        For iC = 0 To iRangeCount - 2
            ColorGrid1.AddPalette(ScalePoints(iC), ScaleColors(iC + iAdd))
            If iAdd = 0 AndAlso iC < iRangeCount - 2 Then
                If ScalePoints(iC + 1) > dTarget Then
                    iAdd = 1
                    ColorGrid1.AddPalette(dTarget, ScaleColors(iC + iAdd))
                End If
            End If
        Next
        ' Add data using palette colors
        iC = 0
                ColorGrid1.Add(y + 1, zValues(iC), x + 1, GetPointColor(zValues(iC)))
                iC += 1
            Next
        Next
    Private Sub SetScalePointsAndScaleColors()
        ' divide value range into desired number of subranges
        dColorStep = (dRMax - dRMin) / CDbl(iRangeCount)
        ReDim ScalePoints(iRangeCount - 2)
        SetStandardScalePoints()
        dTarget = (dRMax + dRMin) / 2.0
        ReDim ScaleColors(iRangeCount - 1)
        SetStandardScaleColors()
    Private Sub SetStandardScalePoints()
        For i As Integer = 0 To iRangeCount - 2
            ScalePoints(i) = dRMin + dColorStep * CDbl(i + 1)
        Next
    Private Sub SetStandardScaleColors()
        Dim iAlpha As Integer = 255
        ScaleColors(0) = Color.FromArgb(iAlpha, 0, 0, 240)
        ScaleColors(1) = Color.FromArgb(iAlpha, 0, 240, 240)
        ScaleColors(2) = Color.FromArgb(iAlpha, 240, 240, 240)
        ScaleColors(3) = Color.FromArgb(iAlpha, 240, 240, 0)
        ScaleColors(4) = Color.FromArgb(iAlpha, 240, 0, 0)
    Private Function GetPointColor(ByVal dVal As Double) As Color
        Dim retCol As Color = Color.Black
        Dim iIndex As Integer
        Try
            iIndex = CInt(Math.Floor(Math.Abs(dVal - dRMin) / dColorStep))
            If iIndex > iRangeCount - 1 Then
                iIndex = iRangeCount - 1
            End If
            If dVal > dTarget Then
                If dVal > ScalePoints(iIndex - 1) Then
                    retCol = ScaleColors(iIndex)
                Else
                    retCol = ScaleColors(iIndex - 1)
                End If
            Else
                If dVal < ScalePoints(iIndex) Then
                Else
                    retCol = ScaleColors(iIndex + 1)
                End If
            End If
        Catch ex As Exception
            MessageBox.Show(ex.Message)
        End Try
        Debug.WriteLine(dVal.ToString & " -> " & iIndex.ToString)
        Return retCol
    End Function
End Class
Re: Bug in ColorGrid Legend using Palette
Post by Yeray » Tue Aug 31, 2010 3:55 pm
Hi TEh,
Could you please tell us in what exact TeeChart v3.2 build can you see a legend without repeated colors in the legend with that code?
TEh
Post by TEh » Mon Sep 06, 2010 12:23 pm
Hello Yeray,
version 3.2.2763.26082
Post by Narcís » Wed Sep 08, 2010 1:45 pm
Hi TEh,
Thanks for the information. I have been able to reproduce the issue here and added it (TF02015141) to the defect list to be fixed.
TEh
Post by TEh » Mon Nov 19, 2012 11:32 am
Hello
Apparently this bug has never been fixed or it has reappeared.
TEh
Post by TEh » Mon Nov 19, 2012 11:41 am
By the way - If I add a new value to the series after the actual values with color.empty as color, the legend shows correct colors
ColorGrid1.Add(0, 0, 0, Color.Empty)
Post by Sandra » Mon Nov 19, 2012 3:56 pm
Hello Teh,
I inform you that this bug is already fixed in build 4.1.2010.02809 (TeeChart for .NET). I have debugged your code and I find that you have made an error in next line of code:
Basically, you assign, the palette to the Grid, previously add values and at the moment to add values, it is contradictory and it causes the problem in last version of TeeChartFor.Net. If you modify the previous line of code for the next:
ColorGrid1.Add(y + 1, zValues(iC), x + 1)
The code works fine.
