I uploaded a project example.
If you open chart editor, and you change the tipo of the "line1" serie from line to points. In the chart list line1 goes to the last position...
I'm using the last version of teechart2010 .net (yesterday)..
Thanks in advance,
Alain
Incorrectly changed the order of the series
Re: Incorrectly changed the order of the series
Hello Alain,
I couldn't reproduce your problem using next sample code:
Could you please, attach a simple example here, because we can reproduce exactly your problem? Moreover, if you already have uploaded your project in upload page, you can say us which are name of file, because we don't find it.
line1.FillSampleValues();
Steema.TeeChart.Styles.Line line2 = new Steema.TeeChart.Styles.Line(tChart1.Chart);
line2.FillSampleValues();
Steema.TeeChart.Styles.Series s = tChart1[0];
Steema.TeeChart.Styles.Series.ChangeType(ref s, typeof(Steema.TeeChart.Styles.Points));
Sorry I thought I had attached the example.
- TestTeechart2010.zip
- (26.98 KiB) Downloaded 441 times
Hello wakeup,
I could reproduce your problem using last version 2010. I have added your request in bug list with number [TF02015077]. We will try to fix it in next versions of TeeChart.Net
I have just downloaded last revisión, and it seems not be solved.
Hello wakeup,
Bug with number (TF02015077) still isn't fixed. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.
