Legend series
Posted: Wed Jul 28, 2010 11:21 am
by 13047867
i want make in my graph series in legend not to 3 line relativly ,i want 2 line in legend like picture with indicated 3.is it possible?Also are they possible that is shown in picture with number1,2,3.if they are possible,how can i make.
Adjustments Activity graph.png (147.95 KiB) Viewed 4356 times
Re: Legend series
Posted: Thu Jul 29, 2010 11:54 am
by 10050769
Hello Solutions Gallery BV,
Could you please explain exactly what are you do with next points, because we can try to help you?
1.- Heat cycle days (= nr of days between 2 heat peaks)
2.- Heat probability.
On the other hand, I made a simple code that I think you can use to achieve sort legend items and do that your legend have two rows, using property of series Exchange and properties of legend MaxNumRows and TextSymbolGap as you can see in next code:
            for (int i = 0; i < 10; i++)
                if (i < 5)
                    new Steema.TeeChart.Styles.Line(tChart1.Chart);
                    tChart1[i].FillSampleValues();
                    new Steema.TeeChart.Styles.FastLine(tChart1.Chart);
            Steema.TeeChart.Legend legend1 = new Steema.TeeChart.Legend(tChart1.Chart);
            tChart1.Legend.Alignment = Steema.TeeChart.LegendAlignments.Bottom;
            tChart1.Legend.MaxNumRows = 2;
            tChart1.Legend.TextSymbolGap = 0;
            int k,j;
            k=0;
            j= tChart1.Series.Count/2;
            while (k < tChart1.Series.Count && j< tChart1.Series.Count)
                    tChart1.Series.Exchange(j,k);
                    j++;
                    k++;
Could you please tell us if previous code works fine for you?
