Chart.Export.Template.Save out of memory
acastro
Post by acastro » Tue Jun 08, 2010 9:51 am
I'm having problems exporting a chart, because the chart has only a serie but with 122,652 values. I get this error:
Property accessor 'DataSource' on object 'Steema.TeeChart.Styles.Line' threw the following exception:'Exception of type 'System.OutOfMemoryException' was thrown.'
I tried running:
          chart.Export.Template.IncludeData = false;
            chart.Export.Template.Save(path);
Because I don't need to save the data, but I think the includeData= false sentence is not running because it spend quite lot time trying to save an then throws the same error...
I tried deleting the data of the serie before save it, but then chart deletes the data to the user and to get it from the database spends too time to get it again transparently.
Do you know any way to solve it?
Re: Chart.Export.Template.Save out of memory
Post by Sandra » Wed Jun 09, 2010 10:38 am
Hello wakeup,
I have tried to reproduce your problem, and here it doesn't appear using next code and changing property chart1.Export.Tamplate.IncludeData to true or false:
        private Steema.TeeChart.TChart chart1, chart2;
        private Steema.TeeChart.Styles.Line line1;
           chart1 = new Steema.TeeChart.TChart();
           chart2 = new Steema.TeeChart.TChart();
           this.Controls.Add(chart1);
           this.chart1.Location = new System.Drawing.Point(-3, 141);
           this.chart1.Size = new System.Drawing.Size(475, 293);
           this.chart1.TabIndex = 0;
           this.Controls.Add(chart2);
           this.chart2.Location = new System.Drawing.Point(493, 141);
           this.chart2.Size = new System.Drawing.Size(453, 293);
           this.chart2.TabIndex = 1;
           line1= new Steema.TeeChart.Styles.Line(chart1.Chart);
           line1.Add(1, 122);
           line1.Add(2, 652);
           chart1.Export.Template.IncludeData = false;//true;
           chart1.Export.Template.Save(@"C://TeeChart1.ten");
           chart2.Import.Template.Load(@"C://TeeChart1.ten");
Please, check if previous code works as you want. If it doesn't work for you, please, modify code because we can reproduce your problem here.
acastro
Post by acastro » Wed Jun 09, 2010 2:42 pm
I tested it better and your are right it doesn't save the data, but it save something big.
I can't reproduce the problem with your example, but I have attached in this post my chart saved without data, but as you can be its size is 3MB!
What is it saving?
Thanks!
example.zip
(423.52 KiB) Downloaded 460 times
Post by Sandra » Thu Jun 10, 2010 8:58 am
Hello wakeup,
Please, could you send us a simple example project we can run "as-is" to reproduce the problem here, we can help you?
acastro
Post by acastro » Fri Jun 11, 2010 9:54 am
I have just uploaded a demo project. Push the "add serie" button, and after the save button and it fails....
Example.zip
(470.11 KiB) Downloaded 486 times
Post by Sandra » Fri Jun 11, 2010 11:12 am
Hello wakeup,
I tested your project using last version of TeeChart .Net. I am following your indications for run your project and it generates a file.tee of 5KB, please see attached file.
test.zip
(1.52 KiB) Downloaded 494 times
Could you say us what version of TeeChart.Net are you using now?
acastro
Post by acastro » Fri Jun 11, 2010 11:45 am
I have just downloaded the last version of teechart and it was solved.
