Legend: dividing lines
Posted: Thu Mar 18, 2010 2:39 pm
by 14045174
I can see a set of problems when I turn on the dividing lines for my legends:
For vertical legends (on left or right):
  • The lines are 1or 2 pixels longer than they should be and therefore are running beyond the right border.
  • If I am using continuous symbols, the dividing lines are 2 or 3 pixels above the border between neighboring symbols
For horizontal legends (on top or bottom) / since this kind of selection is available - it should work correctly /
  • The lines are 1or 2 pixels longer than they should be and therefore are running beyond the bottom border.
  • There is a line before the first column
  • If I happen to have legend title - the lines are crossing the title, which looks really odd.
Re: Legend: dividing lines
Posted: Fri Mar 19, 2010 11:07 am
by 10050769
Hello UserLs,
I could reproduce your problems with legend using last versions of TeeChart.Net. I have added it in list of bug report with number (TF02014738). We will try to fix for next versions of TeeChart.Net.
On the other hand, only I couldn't reproduce here, is that problem:
Here I get next:
Please, you could say if in previous image appears problem indicate above. If it doesn’t appear, please you could send and image, because we can see the problem?
Posted: Fri Mar 19, 2010 6:03 pm
by 14045174
Here is my image. Its name cryptic, but tells what selections are made:
Posted: Mon Mar 22, 2010 9:34 am
by 10050769
Hello UserLs,
I couldn’t reproduce your problem using next code and last version 3 of TeeChart .Net:
            tChart1.Header.Visible = true;
            for (int i = 0; i < 13; i++)
                new Steema.TeeChart.Styles.Bar(tChart1.Chart);
                tChart1[i].FillSampleValues();
                tChart1[i].Title = "Bar" + i.ToString();
            tChart1.Legend.Symbol.Continous = true;
            tChart1.Legend.DividingLines.Visible = true;
            tChart1.Legend.Alignment = Steema.TeeChart.LegendAlignments.Left;
Please, you could modify it, because we can reproduce your problem here?
