MaxValueIndicator Gauge Control
Sven
Post by Sven » Tue Feb 23, 2010 9:47 am
How can I set or reset the MaxValueIndicator in vertival gauge control.
TeeChart buid Version: 4.0.2009.42283
Re: MaxValueIndicator Gauge Control
Post by Yeray » Tue Feb 23, 2010 11:55 am
Hi Sven,
Could you please explain what are you exactly trying to change in the MaxValueIndicator. the following code seems to work as expected here.
            Steema.TeeChart.Styles.VerticalLinearGauge gauges1 = new Steema.TeeChart.Styles.VerticalLinearGauge(tChart1.Chart);
            gauges1.Maximum = 1000;
            gauges1.Value = 500;
            gauges1.MaxValueIndicator.Color = Color.Green;
Also note that the build you are using (4.0.2009.42283) is not the latest (4.0.2009.62332).
Sven
Post by Sven » Thu Feb 25, 2010 8:32 am
Hi Alonso
Thanks for your answer.
The Problem is not the maximum or minimum value of the gauge. I want to reset the MaxValueIndicator in the gauge, after a run. I miss a a property like gauge1.MaxValueIndicator.Reset()
        public void InitGauge()
            textBoxValue.Text = "0";
            verticalLinearGauge.Minimum = MinValue;
            verticalLinearGauge.Maximum = MaxValue;
            verticalLinearGauge.Value = 0.0;
            verticalLinearGauge.Axis.Title.Text = AxisTitle + " " + Unit;
            verticalLinearGauge.GreenLineStartValue = MinValue;
            verticalLinearGauge.GreenLineEndValue = MaxValue * 0.78;
            verticalLinearGauge.RedLineStartValue = MaxValue * 0.8;
            verticalLinearGauge.RedLineEndValue = MaxValue;
            double axisIncrement = (MaxValue / 5);
            verticalLinearGauge.Axis.Increment =  Math.Round(axisIncrement, 2);
            // cannot reset  or init the MaxValueIndicator after a run
            verticalLinearGauge.MaxValueIndicator = MinValue;
            verticalLinearGauge.MaxValueIndicator.Reset();
            verticalLinearGauge.MaxValueIndicator.Clear();
Post by Sandra » Thu Feb 25, 2010 12:42 pm
Hello Sven,
MaxValueIndicator is an object that has many properties associated. Please, could you say us exactly what you want to do Clear() or Reset() methods and what of these properties you would like that be changed
Sven
Post by Sven » Thu Feb 25, 2010 1:56 pm
Hi Sandra
I found the problem with the MaxValueIndicator. I have created an vertical gauge control in the Designer from Studio 2008. If the Form InitilizeComponent() is initilized the gauge control value is the value from designer (gauge1.value = 17.89146576)
Now I create a new gauge Object with gauge.value = 0.0 in a Init() method. If I want to reset the MaxValueIndicator I call the init method and create a new gaugeControl.
            if (!DesignMode)
                verticalLinearGauge1.Dispose();
                tChart3.Series.Remove(verticalLinearGauge1);
                verticalLinearGauge1 = null;
                verticalLinearGauge1 = new Steema.TeeChart.Styles.VerticalLinearGauge();
                verticalLinearGauge1.Value = 0.0;
                verticalLinearGauge1.Maximum = 50;
                verticalLinearGauge1.Minimum = 0;
                tChart3.Series.Add(verticalLinearGauge1);
                PerformLayout();
Thanks for your help !
best regards
sven
Post by Yeray » Tue Mar 02, 2010 4:01 pm
Hi Sven,
Now I understood the problem so I've added it to the wish list to be implemented in future releases (TF02014699).
