Difficulty with Filled Contour Chart.
GrayMoody
Post by GrayMoody » Mon Jan 04, 2010 3:51 pm
I am working to implement a filled Contour chart. With "ThisCurve.FillLevels = false;" I get exactly what I want from a contour chart, except that it's not filled. However, with "ThisCurve.FillLevels = true;" the chart goes completely white, except for a red border and a red "X" drawn as lines from opposing corners. I've tried to use the example code for filled contour charts as much as possible. Any thoughts of what I should be looking for? Thanks!!
ThisCurve.Brush.Color = System.Drawing.Color.FromArgb(((int)(((byte)(68)))), ((int)(((byte)(102)))), ((int)(((byte)(163)))));
//ThisCurve.Brush.Visible = true;
//ThisCurve.Color = System.Drawing.Color.FromArgb(((int)(((byte)(68)))), ((int)(((byte)(102)))), ((int)(((byte)(163)))));
ThisCurve.ColorEach = false;
ThisCurve.EndColor = System.Drawing.Color.FromArgb(((int)(((byte)(0)))), ((int)(((byte)(0)))), ((int)(((byte)(255)))));
ThisCurve.Marks.Brush.Visible = false;
ThisCurve.Marks.Callout.ArrowHead = Steema.TeeChart.Styles.ArrowHeadStyles.None;
ThisCurve.Marks.Callout.ArrowHeadSize = 8;
ThisCurve.Marks.Callout.Brush.Color = System.Drawing.Color.Black;
ThisCurve.Marks.Callout.Distance = 0;
ThisCurve.Marks.Callout.Draw3D = false;
ThisCurve.Marks.Callout.Length = 10;
ThisCurve.Marks.Callout.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
//ThisCurve.Marks.Callout.Visible = false;
ThisCurve.Marks.Transparent = true;
ThisCurve.Marks.Visible = true;
//ThisCurve.MidColor = System.Drawing.Color.FromArgb(((int)(((byte)(128)))), ((int)(((byte)(255)))), ((int)(((byte)(128)))));
ThisCurve.NumLevels = 8; //10;
ThisCurve.PaletteMin = 0;
ThisCurve.PaletteStep = 0;
ThisCurve.PaletteStyle = Steema.TeeChart.Styles.PaletteStyles.Strong;
ThisCurve.Pen.Color = System.Drawing.Color.FromArgb(((int)(((byte)(192)))), ((int)(((byte)(192)))), ((int)(((byte)(192)))));
ThisCurve.Pen.Style = System.Drawing.Drawing2D.DashStyle.Dot;
ThisCurve.Pointer.HorizSize = 2;
ThisCurve.Pointer.Pen.Visible = false;
ThisCurve.Pointer.Style = Steema.TeeChart.Styles.PointerStyles.Rectangle;
ThisCurve.Pointer.VertSize = 2;
ThisCurve.StartColor = System.Drawing.Color.FromArgb(((int)(((byte)(255)))), ((int)(((byte)(0)))), ((int)(((byte)(0)))));
ThisCurve.XValues.DataMember = "X";
ThisCurve.YValues.DataMember = "Y";
ThisCurve.YPosition = 0.18959828428699516;
ThisCurve.ZValues.DataMember = "Z";
Re: Difficulty with Filled Contour Chart.
Post by Sandra » Tue Jan 05, 2010 10:17 am
I made a simple example using FillSampleValues() and FillLevels = true works correctly using last version of TeeChart .Net. Please, could you check if next code works correctly for you?
        private Steema.TeeChart.Styles.Contour ThisCurve;
            ThisCurve = new Steema.TeeChart.Styles.Contour(tChart1.Chart);
            ThisCurve.FillSampleValues();
If previous code works correctly but your application doesn’t work because you are working with database, I recommend make a simple example using DataSet as is explained, here and send us because we can reproduce your problem here.
Furthermore, you could say what is your actually version of TeeChart .Net.
GrayMoody
Post by GrayMoody » Tue Jan 05, 2010 3:00 pm
Thank you Sandra. The example program you sent works correctly and fills the contours, and my version is: TeeChart Pro 3.2.2945.19737. I am not using a database, but manually adding (x,y,z) info using the following code:
public void AddContourPoint(string CurveTitle, double x, double y, double z, Color pointColor)
ThisCurve = (Steema.TeeChart.Styles.Contour)M_CurrentGraph.Series.WithTitle(CurveTitle);
ThisCurve.Add(x, y, z, pointColor);
I'll take a look at the Dataset example you linked, though if it's for database access, it may not be relevant.
I wonder if it could have to do with setting the pointColor. I may try a version that only does: ThisCurve.Add(x, y, z);
Post by Narcís » Tue Jan 05, 2010 3:14 pm
Hi GrayMoody,
Thanks for your feedback.
Also notice there are much newer builds of TeeChart for .NET v3 available at the client area.
Dave
Post by Dave » Thu Jan 14, 2010 10:51 am
Was GrayMoody's query ever solved? I have exactly the same problem in that when I use
myContour.FillSampleValues();
I get a filled contour chart OK as expected
But when I replace "myContour.FillSampleValues();" with my own code that builds up the contour ie. myContour.Add(x,y,z); then I DO NOT get the contour filled. It just shows grey contour lines. Is it possibly because the data doesn't lend itself to being filled? ie. My data is invalid in some way.
Note Ive tried with IrregularGrid = both true and false and the result is the smae in both cases.
GrayMoody
Post by GrayMoody » Thu Jan 14, 2010 3:34 pm
No, my issue was not resolved yet, but I had to project shift to a different priority and haven't gotten back to it yet. Much like you, my code worked fine with FillSampleValues, and would fill the randomly generated contour graph. However, with my own values and FillLevels=true, I did not get any successful graph at all (it looked like a plain white backgroud with a red X crossing it). Interestingly enough, with my data and FillLevels=false, I got a very nice contour graph that accurately depicted my data, only it wasn't filled. I reached the same theory that you have. There must be something about my data which makes filling the contour impossible. But I have not had time to return to experiment further.
Post by Narcís » Thu Jan 14, 2010 3:45 pm
Hi GrayMoody and Dave,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
GrayMoody
Post by GrayMoody » Thu Jan 14, 2010 3:59 pm
Narcis - thank you for helping, but I think I may need to explore more on my side first (when project demands allow me to). While I could send a sample app, I don't think it would help, because the sample apps work completely correctly, every time, on my end. My production app uses a spectrometer to supply data.
In the above posts, Sandra created a sample app, which is really a very close modelling of my actual code (kudos to Sandra). That app performs all functions correctly. The only difference is that Sandra's app uses random values and mine adds data point by point. In order to test whether it's my method for adding data, or the data itself, I'll need to find a means of modelling the spectrometer supplying data. I'm hoping to return to that project soon.
Post by Narcís » Thu Jan 14, 2010 4:04 pm
Hi GrayMoody,
Ok, thanks for your feedback. In that case the only thing it would help would be a sample application simulating spectrometer's data.
Dave
Post by Dave » Mon Feb 01, 2010 2:19 pm
Narcis
How do I upload my sample application (with XML data file) for you to look at.
Post by Narcís » Mon Feb 01, 2010 2:23 pm
Hi Dave,
You can attach it to this forums board. Under the text box you'll find a tab called "upload attachment". It's no necessary to include project's "bin" and "obj" folders.
Alternatively you can post your files to the upload page.
Dave
Post by Dave » Tue Feb 02, 2010 1:53 pm
Hi Narcis
Ive uploaded 2 files. Form.cs looks for the XML Ive uploaded.
Ive replaced your line "newContour.FillSampleValues();" with my code that uses the xml file to create a new contour.
As you can see nothing is rendered (but it renders OK if its not a filled contour just an ordinary contour)
Im wonderng if perhaps there is something invalid about the data that does not allow it to be drawn as a filled contour map.
Post by Yeray » Tue Feb 02, 2010 4:23 pm
Hi Dave,
In your XML I can see 21 Line series but no Contour. Is that the correct file?
Dave
Post by Dave » Wed Feb 03, 2010 3:39 pm
Im very sorry about that. I uploaded the wrong form.cs yesterday.
Ive just uploaded the correct one now. The xml file I sent yesterday is the correct one (the contour map is built up from the series in the xml file)
Post by Narcís » Mon Feb 08, 2010 10:24 am
Hi Dave,
Thanks for the example. The problem is that with such data you need to set Contour's IrregularGrid property to true:
						newContour.IrregularGrid = true;
For more information on how to populate such series types and how IrregularGrid works please read this thread:
http://www.teechart.net/support/viewtop ... 750#p19750
Also, if you let me make a suggestion, IMHO it's much easier to understand and shorter to code populating Contour like this:
						for (int a = 0; a < tChart1.Series.Count; a++)
							for (int b = 0; b < tChart1[a].Count; b++)
								double y1 = tChart1.Series[a].YValues[b];
								y1 = Math.Min(y1, threshold);
								newContour.Add(tChart1[a].XValues[b], y1, (50 + (a * 10)));
Hope this helps!
