Bottom.Labels.Angle could not diretly reflect in chart
Posted: Mon Dec 28, 2009 10:21 am
by 14048132
Hello:
We are using Build 3.5.3498.27376. We use the following code to adjust label angle of bottom axis.
Private Sub TChart_BeforeDrawSeries(ByVal sender As System.Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
        Dim tchart As Steema.TeeChart.Chart = g.Chart
        Dim iWidth As Integer = Math.Abs((tchart.Axes.Bottom.CalcXPosValue(1) - tchart.Axes.Bottom.CalcXPosValue(0))) / 4
       // These codes are used to adjust box width, it works
         For Each series As Steema.TeeChart.Styles.Series In tchart.Series
            If TypeOf (series) Is Steema.TeeChart.Styles.Box Then
                CType(series, Steema.TeeChart.Styles.Box).Box.HorizSize = iWidth
            End If
        Next
      // We use this line to change label angle to 90, but the chart does not reflect to this change
        tchart.Axes.Bottom.Labels.Angle = 90
As you could see in the attached image, the box width is changed with the code, but the axis label angel is not changed.
Box Plot Width and Angel.GIF (9.96 KiB) Viewed 7171 times
But we could see that the angel is changed to 90 in Chart Editor
angel in editor is changed.GIF (18.92 KiB) Viewed 7171 times
Please advise how could we eliminate this issue, thanks
Re: Bottom.Labels.Angle could not diretly reflect in chart
Posted: Tue Dec 29, 2009 10:00 am
by 10050769
Hello Chris. CHWU
I think that your problem occurs because chart needs redraw or refresh. Please see next code and check works correctly.
Dim box1 As Steema.TeeChart.Styles.Box
Dim box2 As Steema.TeeChart.Styles.Box
Dim box3 As Steema.TeeChart.Styles.Box
    Private Sub InitializeChart()
        box1 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
        box1.FillSampleValues()
        box1.Position = 1
        box2 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
        box2.FillSampleValues()
        box2.Position = 2
        box3 = New Steema.TeeChart.Styles.Box(tChart1.Chart)
        box3.FillSampleValues()
        box3.Position = 3
        AddHandler tChart1.BeforeDrawSeries, AddressOf Me.tChart1_BeforeDrawSeries
        tChart1.Draw()
    Private Sub tChart1_BeforeDrawSeries(ByVal sender As Object, ByVal g As Steema.TeeChart.Drawing.Graphics3D)
        Dim iWidth As Integer = (Math.Abs((tchart.Axes.Bottom.CalcXPosValue(1) - tchart.Axes.Bottom.CalcXPosValue(0))) / 4)
            If (TypeOf series Is Steema.TeeChart.Styles.Box) Then
                CType(series,Steema.TeeChart.Styles.Box).Box.HorizSize = iWidth
            End If
        Next
