Rotate Marks with shadows
Posted: Mon Nov 09, 2009 3:34 pm
by 14045174
Have you ever tried to rotate your marks, when they have shadows?
In both my examples I have shadow offsets (3, 3), rotation angle is 45:
- Marks.jpg (27.1 KiB) Viewed 6141 times
Also, note that the text is no longer centered inside the frame!
Re: Rotate Marks with shadows
Posted: Tue Nov 10, 2009 10:52 am
by 10050769
Hello UserLs,
Thank you for the bug report. It is being corrected and the fix will be included in the next maintenance release (v3 and v2009). Bug id. is [TF02014545].
Posted: Tue Dec 15, 2009 3:38 pm
by 14045174
It does work better now, but if my marks are using round rectangle frame and I try to rotate them - forget about round rectangles - they are gone!
Also, you guys obviously have problems with negative numbers. Here, try to rotate marks to 315 and then to -45 degrees (which is really the same angle but the results are really different!)
Posted: Tue Dec 22, 2009 4:25 pm
by narcis
Hi UserLS,
Ok, I have added the issues to the bug list with id. numbers TF02014605 and TF02014606 respectively.
