ChartController in MDI application
acastro
Post by acastro » Fri Oct 30, 2009 9:03 am
I have a ChartController in a mdichild form, it runs successfully, but when I send the chartController to be seen in the mdiParent with "ToolStripManager.Merge" command it doesn't make actions over the chart.
How can I see the chartController of a chart in a mdichild in the toolbar of the mdiparent?
Thanks in advance,
Re: ChartController in MDI application
Post by Narcís » Mon Nov 02, 2009 1:17 pm
Hi wakeup,
Could you please attach a simple example project we can run "as-is" to reproduce the problem here?
acastro
Post by acastro » Mon Nov 02, 2009 4:37 pm
Here you have an example project attached.
If you click New in the tool bar it show a mdichild form and adds the ChartController to the main toolstrip but the chart controller buttons don't run.
I have used this method of transfer toolstrips from mdichild to mdiparent a lot of times without problems, but something is diferent in chartcontroller.
TestChartControllerMdi.zip
(27.1 KiB) Downloaded 518 times
Post by Sandra » Thu Nov 05, 2009 10:15 am
Hello wakeup,
I belive,then investigated, there exist a general problem with ToolStripManager.Merge and not exlusive of TeeChart. I found many webs, that talk about similar problemes with using ToolStripsManager.
Some Links explain similar problems:
1.- First: http://www.tech-archive.net/Archive/Dot ... 01273.html
2.- Second: http://social.msdn.microsoft.com/Forums ... f61bd17dba (I Thinks that in the thread, comment a solution, that you want see four line).
3.- Third: http://jdixon.dotnetdevelopersjournal.c ... cation.htm.
On the other hand, We made a simple example with Winforms, that reproduce the same problem when use ToolStripManager.Merge and ToolStripManager.RevertMerge where demonstrated this problem isn't exlusive of TeeChart. I have added example, finally the post.
Please, you could check if in your application appears same problem? For reproduce the problem see next intruccions:
1.- You open the project, add your TeeChart.Net dll and execute
2.- You be able to see that appears correctly the ToolStrip, and works.
3.- Go to the code and comment line # 2 and uncommnet line #1
4.- Execute the program and push right button.
5.- You be able to see that image of ToolStrip not appears correctly and when you push buttons of toolStrip not works.
Finally, If you find a better solution of links said, would be better greatful , if you comment us.
WindowsFormsApplication1.zip
(16.48 KiB) Downloaded 520 times
