Problem with zooming in two tee chart
Amol
Post by Amol » Thu Oct 01, 2009 11:55 am
While we use two tee charts having same width and height and allow zooming in both tee charts.
Our requirement is whenever we perform zooming in first tee chart then second tee chart should also zoomed automatically with the same ratio as per first tee chart.
Please let us know how can it be possible?
Gautam
Re: Problem with zooming in two tee chart
Post by Yeray » Thu Oct 01, 2009 1:48 pm
Hi Gautam,
Here is an example of how you could do it. You should do the zooms manually because otherwise, calling the Chart2.Zoom.ZoomRect at Chart1's Zoomed event and the same at reverse, it will result in a infinite loop when you'll zoom.
            tChart2.Aspect.View3D = false;
            Steema.TeeChart.Styles.Points points1 = new Steema.TeeChart.Styles.Points();
            points1.FillSampleValues(25);
            Steema.TeeChart.Styles.Points points2 = (Steema.TeeChart.Styles.Points)points1.Clone();
            tChart1.Series.Add(points1);
            tChart2.Series.Add(points2);
            points1.Color = Color.CadetBlue;
            points2.Color = Color.BlueViolet;
            tChart1.Zoom.Allow = false;
            tChart1.Panning.Allow = Steema.TeeChart.ScrollModes.None;
            tChart2.Zoom.Allow = false;
            tChart2.Panning.Allow = Steema.TeeChart.ScrollModes.None;
            tChart1.MouseDown += new MouseEventHandler(tChart1_MouseDown);
            tChart1.MouseUp += new MouseEventHandler(tChart1_MouseUp);
            tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
            tChart2.MouseDown += new MouseEventHandler(tChart1_MouseDown);
            tChart2.MouseUp += new MouseEventHandler(tChart1_MouseUp);
            tChart2.MouseMove += new MouseEventHandler(tChart2_MouseMove);
            tChart2.AfterDraw += new Steema.TeeChart.PaintChartEventHandler(tChart2_AfterDraw);
        private int MouseDownX, MouseDownY, MouseActX, MouseActY;
        private bool Zooming;
        void tChart1_MouseDown(object sender, MouseEventArgs e)
            if (e.Button == MouseButtons.Left)
                MouseDownX = e.X;
                MouseDownY = e.Y;
                Zooming = true;
        void tChart1_MouseUp(object sender, MouseEventArgs e)
            if (Zooming)
                if ((e.X < MouseDownX) && (e.Y < MouseDownY))
                    tChart1.Axes.Left.Automatic = true;
                    tChart1.Axes.Bottom.Automatic = true;
                    tChart1.Invalidate();
                    tChart2.Axes.Left.Automatic = true;
                    tChart2.Axes.Bottom.Automatic = true;
                    tChart2.Invalidate();
                    tChart1.Axes.Left.SetMinMax(tChart1.Axes.Left.CalcPosPoint(e.Y), tChart1.Axes.Left.CalcPosPoint(MouseDownY));
                    tChart1.Axes.Bottom.SetMinMax(tChart1.Axes.Bottom.CalcPosPoint(MouseDownX), tChart1.Axes.Bottom.CalcPosPoint(e.X));
                    tChart2.Axes.Left.SetMinMax(tChart2.Axes.Left.CalcPosPoint(e.Y), tChart2.Axes.Left.CalcPosPoint(MouseDownY));
                    tChart2.Axes.Bottom.SetMinMax(tChart2.Axes.Bottom.CalcPosPoint(MouseDownX), tChart2.Axes.Bottom.CalcPosPoint(e.X));
            Zooming = false;
        void tChart1_MouseMove(object sender, MouseEventArgs e)
            if (Zooming)
                MouseActX = e.X;
                MouseActY = e.Y;
            if (Zooming)
                tChart1.Graphics3D.Pen.Style = System.Drawing.Drawing2D.DashStyle.Dash;
                tChart1.Graphics3D.BackColor = Color.Empty;
                tChart1.Graphics3D.Rectangle(MouseDownX, MouseDownY, MouseActX, MouseActY);
        void tChart2_MouseMove(object sender, MouseEventArgs e)
            if (Zooming)
                MouseActX = e.X;
                MouseActY = e.Y;
        void tChart2_AfterDraw(object sender, Steema.TeeChart.Drawing.Graphics3D g)
            if (Zooming)
                tChart2.Graphics3D.Pen.Style = System.Drawing.Drawing2D.DashStyle.Dash;
                tChart2.Graphics3D.BackColor = Color.Empty;
                tChart2.Graphics3D.Rectangle(MouseDownX, MouseDownY, MouseActX, MouseActY);
Amol
Post by Amol » Sat Oct 03, 2009 6:58 am
Hi Yeray ,
thanks for ur reply.
Now, my problem is solved.
Gautam
