TeeChart for .NET [24 SEP 2009] - problems under VS2005
ATV
Post by ATV » Mon Sep 28, 2009 8:13 am
I have uninstalled 4.0.2009.21354 and installed the new version.
I have used the TeeRegV2009 utility (because of problems with registration in older versions of TChart)
I have updated the licenses.licx file.
The following problem occurs: if the context menu of the TChart appears, all menu items (Edit ... , Clear ...) for the TChart are not available.
This happens too if I remove the TChart-object and add a new instance ...
I rolled back to 4.0.2009.21354 and all menu items are available again ...
Any ideas ??
Re: TeeChart for .NET [24 SEP 2009] - problems under VS2005
Post by Yeray » Thu Oct 01, 2009 7:50 am
Hi ATV,
Note that the version from 24th September was labeled 4.0.2009.28593 while the version you mention corresponds to 30th June.
I've tested the installer of TeeCahrt for NET v4 for VS2005 actually downloadable from the web and it seems to work fine.
ATV
Post by ATV » Thu Oct 01, 2009 1:54 pm
I wrote:
... UNINSTALLED 4.0.2009.21354 ...
--> I have used the V4.0.2009.21354 up to now
Post by Sandra » Fri Oct 02, 2009 9:20 am
Hello ATV,
First, I have comunicated number of version that Yeray said, is not the last version of 24th September. Second we couldn't reproduce your problem here. Please you could try download 24th September was labeled 4.0.2009.35591, because installer may be corrupt.
On the other hand, TeeRegV2009 is not necessary, you can download directly the installer.
