Bar Series Bottom AxisLabels > Rectangle Memory Creep
Diegoa
Re: Bar Series Bottom AxisLabels > Rectangle Memory Creep
Post by Diegoa » Wed Aug 29, 2012 7:27 am
Will do, thanks
Diegoa
Post by Diegoa » Wed Aug 29, 2012 10:53 am
Ok gave it a test, no creep at all :)
Post by Narcís » Wed Aug 29, 2012 11:15 am
Hi Diego,
I'm glad to hear that, thanks for your feedback!
You can expect the fix being included in the next TeeChart for .NET 2012 maintenance release.
faffle
Post by faffle » Tue Jan 15, 2013 7:01 pm
I am experiencing the same issue with the mobile version (TeeChart.Pocket.dll) v4.1.2012.092830 for .Net CF 3.5.
I have used the work around noted above, but in my case I had to include the vertical axis.
tChart1.Series[0].GetVertAxis.Labels.Items.Clear()
Could the same fix be applied to the mobile version?
Post by Sandra » Wed Jan 16, 2013 1:06 pm
Hello faffle,
I can not reproduce your problem using attached project and last version of TeeChartFor.Net.
SmartDeviceProject3.zip
(16.62 KiB) Downloaded 421 times
Could you please check if my code works without problems? If my code doesn't help you, could you please arrange for us a simple project where your problem appears because we try to find a solution for you?
