Add function use?
coldwind
Add function use?
Post by coldwind » Tue Jan 17, 2023 4:51 am
hello:
i can see these code in InitializeComponent function which is generate automaticlly.
this.bar1.XValues.DataMember = "X";
this.bar1.YValues.DataMember = "Bar";
i want to use code :
Add(new {X=1,Bar=10.22});
Add(new {X=2,Bar=15.65});
to show chart .but it's nothing.
class Student {
string name;
int age;
//int weight;
so when i want to show my Student class data to chart , which set x axis is "name", set y axis is "age", how i need to do?
I want to code with these style:
this.bar1.XValues.DataMember="name";
this.bar1.XValues.DataMember="age";
this.tChart1[0].Add(new Student ('TOM',10));
this.tChart1[0].Add(new Student ('Lily',10));
this.tChart1[0].Add(new Student ('Jack',16));
Re: Add function use?
Post by Christopher » Tue Jan 17, 2023 11:19 am
yes, you can use the IList overload of the Add function to do this, e.g.
      var bar = new Bar(tChart1.Chart);
      var list = new List<Student>
        new Student { Age = 10, Name = "Tom" },
        new Student { Age = 10, Name = "Lily" },
        new Student { Age = 16, Name = "Jack" }
      bar.YValues.DataMember = "Age";
      bar.LabelMember = "Name";
      bar.Add(list as IList);
Which gives me:
Screenshot from 2023-01-17 12-18-24.png (25.68 KiB) Viewed 6512 times
coldwind
Post by coldwind » Thu Jan 19, 2023 6:30 am
Think you.
But i hope the Mark can custom.
e.g. set the format is
$"{Name} is {Age}"
so the chart show like :
And I hope the mouse hover the Specified bar ,then the Mark will show like above.When the mouse leave the Specified bar ,the Mark will hide.
Post by Christopher » Thu Jan 19, 2023 9:20 am
yes, you can achieve this with code such as the following:
      var markstip = new MarksTip(tChart1.Chart);
      void Bar_GetSeriesMark(Series Series, GetSeriesMarkEventArgs e)
        e.MarkText = $"{list[e.ValueIndex].Name} is {list[e.ValueIndex].Age}";
      bar.GetSeriesMark += Bar_GetSeriesMark;
