Pie chart values - off center slices
Bank Van Breda
Post by Bank Van Breda » Tue May 08, 2018 1:29 pm
Screen Shot 2018-05-08 at 15.27.21.png (59.69 KiB) Viewed 22762 times
Any reason why the slice center points are not stopping in the center of the pie chart?
The values for the middle one are these by the way
pieData.Data.Add(new GraphData() { Value = 81, Color = Color.FromHex("#B9C4D8") });
pieData.Data.Add(new GraphData() { Value = 1, Color = Color.FromHex("#1D386D") });
pieData.Data.Add(new GraphData() { Value = 10, Color = Color.FromHex("#F5A623") });
pieData.Data.Add(new GraphData() { Value = 5, Color = Color.FromHex("#BBC3D3") });
pieData.Data.Add(new GraphData() { Value = 3, Color = Color.FromHex("#1D386D") });
Re: Pie chart values - off center slices
Post by Sandra » Wed May 09, 2018 12:46 pm
Hello Bank Van Breda,
I would like inform you that the Pen problems is added in Teechart Xamarin.iOS Bugzilla tracker to review the problem to upcoming maintenance release. Here's the link: http://bugs.teechart.net/show_bug.cgi?id=2033
On the other hand, finally, we have found a good solution, that allow to explode any pie slice. The code below show you how can do it:
		public MainPage()
			tChart1 = new ChartView();
			tChart1.Chart.Panning.Allow = ScrollModes.None;
			tChart1.Chart.Panel.Gradient.Visible = false;
			tChart1.Chart.Panel.Color = Color.White;
			tChart1.Chart.Walls.Back.Visible = false;
			tChart1.Chart.Header.Visible = false;
			tChart1.Chart.Legend.Visible = false;
			tChart1.Chart.Aspect.View3D = false;
			Steema.TeeChart.Styles.Pie pie1 = new Steema.TeeChart.Styles.Pie(tChart1.Chart);
			pie1.Add(81, Color.FromHex("#B9C4D8"));
			pie1.Add(1, Color.FromHex("#1D386D"));
			pie1.Add(10, Color.FromHex("#F5A623"));
			pie1.Add(5, Color.FromHex("#BBC3D3"));
			pie1.Add(3, Color.FromHex("#BBC3D3"));
			pie1.Marks.Visible = false;
			pie1.AutoPenColor = false;
			pie1.Pen.Visible = false;
			pie1.Circled = true;
			pie1.ExplodedSlice[0] = 5;
			pie1.ExplodedSlice[1] = 10;
			pie1.ExplodedSlice[2] = 5;
			pie1.ExplodedSlice[3] = 15;
			pie1.ExplodedSlice[4] = 5;
			tChart1.WidthRequest = 650;
			tChart1.HeightRequest = 350;
			Content = new StackLayout
				Children =
										tChart1
				VerticalOptions = LayoutOptions.CenterAndExpand,
				HorizontalOptions = LayoutOptions.CenterAndExpand,
Hoping this helps you.
Thanks in advance
Bank Van Breda
Post by Bank Van Breda » Mon May 14, 2018 11:09 am
I guess I'll wait for the bug fix... because setting each slice as exploded with value 5 has following visual effect.
Screen Shot 2018-05-14 at 13.08.17.png (72.41 KiB) Viewed 22741 times
Post by Sandra » Mon May 14, 2018 3:31 pm
I would like inform you we're working to fix the problem. We contact with you as soon as possible.
Thanks in advance
Post by Sandra » Thu May 17, 2018 12:40 pm
We have published a new TeeChart.Net for Xamarin.Froms maintenance release where the bug id2033 is fixed. You can download it from Client Download page
Thanks in advance
Bank Van Breda
Post by Bank Van Breda » Fri May 18, 2018 2:27 pm
Thanks for the great support! Now works as expected :)
