Rotate does not work with Legend Checkboxes
DEV1
Post by DEV1 » Mon Aug 29, 2016 6:35 am
Points points = new Points();
points.Add(10);
MyTChart.Series.Add(points);
var rotate = new Rotate();
MyTChart.Tools.Add(rotate);
MyTChart.Legend.CheckBoxes = true;
I am trying to apply rotate with legend checkboxes.
When rotate is not implemented, legend checkboxes work fine.
But when rotate is implemented, legend checkboxes never work fine.
It seems that it has been posted on wpf forum, too.
URL is http://www.teechart.net/support/viewtop ... =4&t=14057.
It would be great if you let me know as soon as possible about this issue.
Re: Rotate does not work with Legend Checkboxes
Post by Christopher » Mon Aug 29, 2016 2:14 pm
DEV1 wrote: It would be great if you let me know as soon as possible about this issue.
This is now ticket id=1612, which you can see has now been fixed. The fix for this issue is a one-liner, and if you have the source-code version of TeeChart I can tell you where it is.
DEV1
Post by DEV1 » Tue Aug 30, 2016 2:09 am
You mean that it has been fixed with a new dll? I have installed a package on my computer though..
DEV1
Post by DEV1 » Tue Aug 30, 2016 2:10 am
Christopher wrote:Hello,
I thought this might be fixed by changing dll file, but it seems like there is another way to do it?
DEV1
Post by DEV1 » Tue Aug 30, 2016 2:42 am
I think that it would be great if a modified dll is released for this issue as this issue is clearly a bug.
Post by Christopher » Tue Aug 30, 2016 8:32 am
DEV1 wrote:I think that it would be great if a modified dll is released for this issue as this issue is clearly a bug.
Yes, a new maintenance release for TeeChart.NET is expected to be released in the first half of September.
DEV1
Post by DEV1 » Wed Aug 31, 2016 12:39 am
In case it gets delayed, I would like to know what I need to change for the source code.
Post by Christopher » Wed Aug 31, 2016 7:57 am
DEV1 wrote:In case it gets delayed, I would like to know what I need to change for the source code.
Of course - the change is here:
PidoTech
Post by PidoTech » Thu Jan 26, 2017 5:40 am
Is this issue fixed yet? I want to know if this issue has been fixed.
Post by Christopher » Thu Jan 26, 2017 12:12 pm
PidoTech wrote:Is this issue fixed yet? I want to know if this issue has been fixed.
Yes, that change is in the last publicly available release - ID1612 here.
