How to Print Axis Labels for Extended Scaling of Bottom Axis
Quant
Post by Quant » Tue Oct 18, 2016 6:00 am
How to Print Axis Labels for Extended Scaling of Bottom Axis?
Problem Description:
We need to show axis labels (of bottom axis) for extended scales for which actual chart data is not loaded. Let us take an example, wherein we created a sample candle-line chart and fill 1000 sample values. At run-time, we opened Chart Properties and increased Minimum and Maximum Scales of bottom axis. The problem here as shown in attached screenshot is, it does not display any axis labels for that extended scales.
Figure 6.png (35.66 KiB) Viewed 7787 times
Please check the above scenario and let us know about any workaround for this asap.
Re: How to Print Axis Labels for Extended Scaling of Bottom Axis
Post by Christopher » Tue Oct 18, 2016 11:15 am
Would you please be so kind as to produce a Minimal, Complete, and Verifiable example of your problem, as shown in this StackOverflow article here?
