While Converting series to Kagi it compresses
Quant
Post by Quant » Tue Mar 29, 2016 5:29 am
1) when I convert candle series to Kagi it compresses to half of timeline. can you give solution to make it as per datetime bottom axis.
2) also when I revert series type to candle with Series.ChangeType it doesn't clear Kagi series.
Re: While Converting series to Kagi it compresses
Post by Christopher » Tue Mar 29, 2016 3:47 pm
The Kagi series is an unusual series type in the sense that it draws its own axes labels. This means that to convert from Candle to Kagi requires code similar to the following:
      tChart1.Series.Add(typeof(Candle)).FillSampleValues();
      Series series = tChart1[0];
      Series.ChangeType(ref series, typeof(Kagi));
      tChart1.Clear();
      tChart1.Series.Add(series);
and from Kagi to Candle:
      tChart1.Series.Add(typeof(Kagi)).FillSampleValues();
      Series.ChangeType(ref series, typeof(Candle));
      tChart1.Clear();
Quant
Post by Quant » Wed Mar 30, 2016 3:22 am
and what about compression irrespective of X Axis. i.e. value of 2015 is shown at 2007.
Post by Christopher » Wed Mar 30, 2016 8:22 am
Quant wrote:and what about compression irrespective of X Axis. i.e. value of 2015 is shown at 2007.
In the two code examples I posted this effect is not seen. Would you please be so kind as to post a Minimal, Complete, and Verifiable example so I can reproduce the issue here?
