ScrollPager not working properly
DaVinci
Post by DaVinci » Thu Jun 25, 2015 2:05 pm
I have in VS designer a TChart component placed on a form and activated the ScrollPager like this:
When I run my sample application, I get this window:
The ScrollPager is positioned to minimum and maximum 0, which is acceptable because no data is available for Series.
Now when I load data pressing the Data button (= line1.FillSampleValues(100);) I get this:
The ScrollPager is still positioned to 0 and I can't move the minimum or maximum.
What's wrong? Do I need to use a 'redraw' and where can I find this?
Re: ScrollPager not working properly
Post by Christopher » Fri Jun 26, 2015 12:39 pm
The ScrollPager tool needs to be reassigned the series once this has had its data changed, i.e.
      series1.FillSampleValues();
      tool1.Series = series1;
DaVinci
Post by DaVinci » Fri Jun 26, 2015 2:10 pm
Like always, a simple answer :).
Thanks Christoper.
