Using none zero Origin on a bar series.
tms4000
Post by tms4000 » Thu Jun 05, 2014 6:29 pm
I have a horizontal bar chart with 2 series. One series is a percentage using the left axis. The axis is set to run from 0% to 100%. The second series is using the right axis and represents a temperature. Potential values are -40 - 160. I would like the second series bar to start at the base of the chart instead of starting at zero.
However that is not how it's rendering. I tried setting UseOrigin to true and Origin to -40, but it didn't make a difference.
I've also posted my question on stackoverflow.com here:
http://stackoverflow.com/questions/2406 ... rigin-inst
I have included a screen capture so you can see my code and see how it rendering.
An unrelated problem I'm having is no matter what property I change, I can't see to get the background of the graph to render as white. It always seems to be battleship grey.
Re: Using none zero Origin on a bar series.
Post by Christopher » Fri Jun 06, 2014 9:07 am
Hello!
tms4000 wrote:I have a horizontal bar chart with 2 series. One series is a percentage using the left axis. The axis is set to run from 0% to 100%. The second series is using the right axis and represents a temperature. Potential values are -40 - 160. I would like the second series bar to start at the base of the chart instead of starting at zero.
The following code:
      tChart1.Axes.Right.Grid.Visible = false;
      tChart1.Axes.Right.Maximum = 160.0;
      tChart1.Axes.Right.Minimum = -40;
      tChart1.Axes.Right.Increment = 40;
      tChart1.Axes.Right.Automatic = false;
      tChart1.Axes.Right.AutomaticMinimum = false;
      tChart1.Axes.Right.AutomaticMaximum = false;
      tChart1.Panel.Bevel.Inner = Steema.TeeChart.Drawing.BevelStyles.None;
      tChart1.Panel.Bevel.Outer = Steema.TeeChart.Drawing.BevelStyles.None;
      tChart1.Axes.Left.Grid.Visible = false;
      tChart1.Axes.Bottom.Grid.Centered = false;
      tChart1.Axes.Bottom.Ticks.Visible = false;
      tChart1.Axes.Left.Automatic = false;
      tChart1.Axes.Left.Minimum = 0;
      tChart1.Axes.Left.Maximum = 100;
      tChart1.Axes.Right.Visible = true;
      var barProduct = new Steema.TeeChart.Styles.Bar();
      barProduct.MultiBar = MultiBars.Side;
      barProduct.Color = Color.Green;
      barProduct.Marks.Visible = false;
      barProduct.Title = "% Vol";
      barProduct.ShowInLegend = true;
      Random rnd = new Random();
      for (int i = 0; i < 10; i++)
        barProduct.Add(rnd.Next(0, 100));
      tChart1.Series.Add(barProduct);
      var barTemperature = new Steema.TeeChart.Styles.Bar();
      barTemperature.MultiBar = MultiBars.Side;
      barTemperature.Color = Color.FromArgb(153, 74, 11);
      barTemperature.Marks.Visible = false;
      barTemperature.VertAxis = VerticalAxis.Right;
      barTemperature.UseOrigin = true;
      barTemperature.Origin = -40;
      barTemperature.Title = "Temperature";
      barTemperature.ShowInLegend = true;
        barTemperature.Add(rnd.Next(-40, 160));
      tChart1.Series.Add(barTemperature);
      tChart1.Panel.Gradient.Visible = false;
      tChart1.Walls.Back.Gradient.Visible = false;
      tChart1.Panel.Color = Color.White;
      tChart1.Walls.Back.Color = Color.White;
gives me the following chart:
Do you get the same results at your end?
tms4000
Post by tms4000 » Sat Jun 07, 2014 3:07 am
If I use your code, I get the same result as you.
I messed around and determined the issue is related to the mutibar property.
My origin code snippet left out some details, that in retrospect I should have included.
I actually have 5 series: Product, SP1, SP2, SP3 alll with Multibar = Multibar.Stacked & StackGroup = 1
The last series is the temperature series.
I need the first 4 series to be stacked together and use the left axis.
I need the temp series to stand alone and use the right axis (-40 to 160)
When I remove the SP1 SP2 and SP3 series and change the Mutibar property on the product seriers to MultiBars.Side, the Temperature series responds correctly to the origin property.
When I set Product.Multibar = Multibar.Stacked, the temperature series acts like 0 is the origin.
Post by Christopher » Mon Jun 09, 2014 9:09 am
tms4000 wrote:When I remove the SP1 SP2 and SP3 series and change the Mutibar property on the product seriers to MultiBars.Side, the Temperature series responds correctly to the origin property.
Just to confirm exactly what the issue is. I think I can reproduce the problem using this code:
      for (int j = 0; j < 3; j++)
        barProduct.MultiBar = MultiBars.Stacked;
        barProduct.StackGroup = 0;
      barTemperature.MultiBar = MultiBars.Stacked;
      barTemperature.StackGroup = 1;
which gives me this chart:
is this the issue you're referring to? If so I'll add it to http://bugs.teechart.net/ if you haven't done so already.
tms4000
Post by tms4000 » Mon Jun 09, 2014 1:17 pm
Yes, that's the issue I'm seeing.
I have not posted it to your bug tracker. Could I be informed when this issue is addressed?
Post by Christopher » Tue Jun 10, 2014 8:28 am
tms4000 wrote:Yes, that's the issue I'm seeing.
The bug is has been posted here and has already been fixed; the fix will become publicly available in the next maintenance release, due out mid-summer.
