Axis title being overwritten by axis labels
JCincotta
Post by JCincotta » Mon Jul 15, 2013 8:23 pm
The attached image shows the y-axis title being overwritten by the y-axis labels. When this chart was first drawn, the max value on the y-axis was only 3-digits. But the user can interact with the chart changing the range up to 1,00,000. As this happens, the space reserved for the y-axis labels is not increased and the new labels overlap the y-axis title. Is there some setting that will cause the axis layout to dynamically recalculate as the range is changed? If not, is there a method I can call to ask TeeChart to update the layout reflecting the new range?
Image showing the problem with axis label placement
Re: Axis title being overwritten by axis labels
Post by Sandra » Tue Jul 16, 2013 12:13 pm
Hello JCincotta,
I have made a simple code where you can use to positioning the title of axes correctly and prevent the overlap:
      tChart1.Header.Visible = false;
      tChart1.Legend.Alignment = LegendAlignments.Bottom;
      Random rnd = new Random();
      for (int i = 0; i < 3; i++)
        new Steema.TeeChart.Styles.Line(tChart1.Chart);
        for (int j = 0; j < 20; j++)
          tChart1[i].Add(j, rnd.Next(5000000));
      tChart1.Panel.MarginUnits = PanelMarginUnits.Pixels;
      tChart1.Axes.Left.Title.Visible = true;
      tChart1.Axes.Left.Title.Text = "Y values of Line Series";
      tChart1.Axes.Left.Title.Angle = 90;
      tChart1.Draw();
      PlaceAxes(0, 0, 0, 0, 0);
      tChart1.AfterDraw += new PaintChartEventHandler(tChart1_AfterDraw);
      tChart1.Draw();
    private void PlaceAxes(int nSeries, int NextXLeft, int NextXRight, int MargLeft, int MargRight)
      const int extraPos = 12;
      const int extraMargin = 50;
      //Variable
      int MaxLabelsWidth;
      int lenghtTicks;
      int extraSpaceBetweenTitleAndLabels;
      MaxLabelsWidth = tChart1.Axes.Left.MaxLabelsWidth();
      lenghtTicks = tChart1.Axes.Left.Ticks.Length;
      extraSpaceBetweenTitleAndLabels = (tChart1.Axes.Left.Title.Width);//- tChart1.Axes.Custom[nSeries].MaxLabelsWidth());
      if (tChart1.Axes.Left.Title.Visible)
        tChart1.Axes.Left.RelativePosition = NextXLeft;
        NextXLeft = NextXLeft - (MaxLabelsWidth + lenghtTicks + extraSpaceBetweenTitleAndLabels + extraPos);
        MargLeft = MargLeft + extraMargin;
      tChart1.Panel.MarginLeft = MargLeft;
JCincotta
Post by JCincotta » Mon Jul 22, 2013 10:12 pm
No, I'm afraid this doesn't help. In my graph, Panel.MarginLeft is always just 3.0 and setting it to a larger value just gives me wasted space along the left edge.
Fooling around with the many properties on the chart (thanks for those, btw!), I think I found my answer. I believe all that is necessary is:
    tChart1.Axes.Left.FixedLabelSize = false;
Post by Sandra » Tue Jul 23, 2013 11:52 am
Hello JCincotta,
Thanks for your information. I am glad you have found a good solution for you :). On the other hand, if you have any problems please let me know.
