Maximum value of Left Axis
OMP
Post by OMP » Thu Apr 18, 2013 1:08 pm
Dear,
We have an issue when trying to set the maximum value for the left axis.
This is my code snippet:
chartToTest.Aspect.View3D = false;
chartToTest.Axes.Left.AutomaticMaximum = false;
chartToTest.Axes.Left.Maximum = 1400;
Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(chartToTest.Chart);
bar.MarksOnBar = true;
bar.Add(1, 1000);
bar.Add(2, 1200);
bar.Add(3, 900);
bar.Add(4, 800);
So, as you can see, I set the maximum value for the left axis to 1400.
But, if you take a look to the chart in the attached screenshot, you can see that the maximum is 1550.
What can I do to have the maximum set to 1400.
Thanks in advance,
Marijke Van Bergen
Re: Maximum value of Left Axis
Post by Sandra » Thu Apr 18, 2013 4:14 pm
Hello Marijke Van Bergen,
My recommendation is change the value of MaximumOffset if you want the axis left values are changed correctly. See next line of code:
 tChart1.Axes.Left.MaximumOffset = 1;
OMP
Post by OMP » Mon Apr 22, 2013 10:20 am
Hello Sandra,
Thanks for your suggestion, but unfortunately this does not help.
I added the MaximumOffset to my code, but chart still looks the same.
Kind regards,
Marijke
Post by Sandra » Mon Apr 22, 2013 2:07 pm
Hello Marijke,
Could you tell us which version of TeeChartFor.Net are you using, because next code works fine for me in latest version of TeeChartFor.Net 2012?
            Steema.TeeChart.Styles.Bar bar = new Steema.TeeChart.Styles.Bar(tChart1.Chart);
            bar.Add(1, 1000);
            bar.Add(2, 1200);
            bar.Add(3, 900);
            bar.Add(4, 800);
            tChart1.Axes.Left.AutomaticMaximum = false;
            tChart1.Axes.Left.Maximum = 1400;
OMP
Post by OMP » Tue Apr 23, 2013 2:38 pm
Hi Sandra,
Sorry... my mistake. I tested once more and now I see that it works. Thanks for your help.
Marijke
Post by Sandra » Wed Apr 24, 2013 7:17 am
Hello Marijke,
I am glad that my code works for you :D.
