Line next to Y Axis
Line next to Y Axis
Have a line graph with a scale of -100 to 100, but require a line at 0, I have added a line but using value of 0, but this needs to be right next to the 0 on the Y-Axis with no gap, but still maintain the gap on the other lines.
- graph.JPG (84.53 KiB) Viewed 16393 times
Re: Line next to Y Axis
Hello mikethelad,
Ok. I have made a simple project where the first line is drawn gap to left axis and second line is drawn on the left axis. To achieve it I have used a extra horizontal axis I have assigned to second line. Please, see next code:
Could you tell us if previous code works in your end? If you have any problems please let me know.
Steema.TeeChart.Styles.Line line1, line2;
Steema.TeeChart.Axis axis1;
line1 = new Line(tChart1.Chart);
line2 = new Line(tChart1.Chart);
//Custom Horizontal Axis
axis1 = new Axis(tChart1.Chart);
axis1.Horizontal = true;
tChart1.Axes.Custom.Add(axis1);
//Populate
Random rnd = new Random();
for (int i = 0; i < 10; i )
line1.Add(((i 100)*2), rnd.Next(100));
line2.Add(((i 100)* 2),0);
//Assign line axis
line1.HorizAxis = HorizontalAxis.Bottom;
line2.CustomHorizAxis = axis1;
// Customize axis.
tChart1.Axes.Left.SetMinMax(-100, 100);
tChart1.Axes.Bottom.StartPosition = 1;
tChart1.Axes.Left.AxisPen.Visible = false;
tChart1.Axes.Bottom.AxisPen.Visible = false;
axis1.SetMinMax(line2.XValues.Minimum, line2.XValues.Maximum);
axis1.Labels.Visible = false;
axis1.AxisPen.Visible = false;
Thanks, does not like the following line
Hello mikethelad,
Sorry, but I don't understand what is the problem because the code works in correct way for me. Would be very grateful if you can tell us the exactly problem you have with line of code tChart1.Axes.Custom.Add(axis1);
See attached screen shot
- error.JPG (54.83 KiB) Viewed 16297 times
Hello mikethelad,
Ok. I have attached my test project that works fine in my machine. Please, check if the code works in your end.
I am using Visual Studio 2008, could that be why?
Hello mikethelad,
Ok. I have attached a project made in VS2008. Please, check if it works in your end.
Ok that work fine, will have to try work out the issue with my app, as mine is a web app
Can the -100, 0 , 100 on the Y Axis scale be made bold?
Can the X Axis be inline with -100 and not below, I have the following code for the scale
WebChart1.Chart.Axes.Left.SetMinMax(-100, 100);
Hello mikethelad,
Thanks for information. Now I see the problem in your code. I have modify my code for you because it works with WebChart, please check if code works in your end:
I hope will be help.
protected void Page_Load(object sender, EventArgs e)
WebChart1.Chart.Aspect.View3D = false;
line1 = new Line(WebChart1.Chart);
line2 = new Line(WebChart1.Chart);
axis1 = new Axis(WebChart1.Chart);
WebChart1.Chart.Axes.Custom.Add(axis1);
line1.Add(((i 100) * 2), rnd.Next(100));
line2.Add(((i 100) * 2), 0);
line1.VertAxis = VerticalAxis.Left;
line2.VertAxis = VerticalAxis.Left;
WebChart1.Chart.Axes.Bottom.StartPosition = 1;
WebChart1.Chart.Axes.Left.AxisPen.Visible = false;
WebChart1.Chart.Axes.Bottom.AxisPen.Visible = false;
Great, works see new sample,
Can the X Axis be inline with -100 and not below?
- graph1.JPG (81.17 KiB) Viewed 16279 times
Hello mikethelad,
I am afraid I can not reproduce your problem using last version of TeeChartFor.Net, could you tell us which version are you using? On the other hand, a solution for you is change the minimum offset of Left Axis, as do in next line of code:
WebChart1.Chart.Axes.Left.MinimumOffset = -1;
Thanks, had this set for some reason
WebChart1.Chart.Axes.Left.MinimumOffset = 15;
Assume Bold of the 0 ,100 and - 100 on the scale is not possible
Hi mikethelad,
Is not possible to customize the font style for specific labels. For that you should use custom axis labels as demoed in the All Features\Welcome\Axes\Custom labels example at the features demo, available at TeeChart's program group.
