WPF export chart to Metafile
MVuser2
Post by MVuser2 » Mon Jun 25, 2012 3:39 pm
i understand that in the WPF version we cannot export the chart to metafile.
we had some problems at the past with other formats(most of them were related to the aspect of the picture).
which options i have in WPF teechart and which one is the most close to metafile?
p.s,
it should be a type that can be shown later on on a picturebox.
Re: WPF export chart to Metafile
Post by Sandra » Tue Jun 26, 2012 3:09 pm
Hello MVuser2,
My only suggestion to work with metafiles in wpf is export as a bitmap as explain in this link to achieve work with a metafile.
MVUser6
Post by MVUser6 » Mon Aug 20, 2012 10:42 am
the problem persist.
with WPF bitmap(and other image formats) there is Pixelization of the picture. it doesn't matter that afterwards i'm converting it to a metafile, because it already Pixelizated.
Post by Narcís » Tue Aug 21, 2012 1:15 pm
Hi MVUser6,
I'm using the code snippet below which produces the attached bitmap and copies it in metafile format in the clipboard. I don't think any of the resultant images suffers from aliasing. Could you please give us more detailed information about the problem you are experiencing and modify the code below so that we can reproduce the problem here?
  public partial class MainWindow : Window
    public MainWindow()
      tChart1.Series.Add(new Steema.TeeChart.WPF.Styles.Line()).FillSampleValues();
      string fileName = @"c:\temp\wpf.bmp";
      tChart1.Export.Image.Bitmap.Width = 800;
      tChart1.Export.Image.Bitmap.Height = 600;
      tChart1.Export.Image.Bitmap.Save(fileName);
      System.Drawing.Bitmap gdiBitmap = null;
      System.IO.MemoryStream metafileStream = null;
      try
        gdiBitmap = (System.Drawing.Bitmap)System.Drawing.Bitmap.FromFile(fileName);
        metafileStream = MakeMetafileStream(gdiBitmap);
        var dataObj = new DataObject();
        dataObj.SetData(DataFormats.Bitmap, gdiBitmap);
        dataObj.SetData(DataFormats.EnhancedMetafile, metafileStream);
        Clipboard.SetDataObject(dataObj, true);
      catch
      finally
        if (gdiBitmap != null)
        { gdiBitmap.Dispose(); }
        if (metafileStream != null)
        { metafileStream.Dispose(); }
    private static System.IO.MemoryStream MakeMetafileStream(System.Drawing.Bitmap image)
      System.Drawing.Graphics graphics = null;
      System.Drawing.Imaging.Metafile metafile = null;
      var stream = new System.IO.MemoryStream();
      try
        using (graphics = System.Drawing.Graphics.FromImage(image))
          var hdc = graphics.GetHdc();
          metafile = new System.Drawing.Imaging.Metafile(stream, hdc);
          graphics.ReleaseHdc(hdc);
        using (graphics = System.Drawing.Graphics.FromImage(metafile))
        { graphics.DrawImage(image, 0, 0); }
      finally
        if (graphics != null)
        { graphics.Dispose(); }
        if (metafile != null)
        { metafile.Dispose(); }
      return stream;
wpf.zip
(73.68 KiB) Downloaded 493 times
